I sure will, If it sounds good I will buy one as-well. :D
Printable View
Ok...here is a quick video that I made of the sound of the exhaust before and after the installation.
http://www.youtube.com/watch?v=LtvnyiFrKtY
The installation went pretty well, and quick!
Only had to cut the tailpipe just after the muffler in order to easily remove the old exhaust.
Everything else was easily bolted together. Just be wary of the hoses and vacuum lines just above the rear differential when routing the left side pipe...you don't want to pinch them between the frame and pipe.
Also, make sure you put the heatshield around these same lines.
