Results 1 to 2 of 2
Thread: Battery Drain
    Default Battery Drain
    Hi everyone. New to the forum. I have a 2002 Chevy Suburban with a killer parasitic drain on the battery. I've read all the thread in this and other forums and I'm still stuck. I can't narrow it down to just the BCM. The only way to kill it is to pull the under-fuses marked TBC, RADIO, and SEO1. But none of the three is a consistent portion of the draw. It is driving me nuts. Anyone out there with some tips?
    Does it has lighted mirrors on the sun visors? I have seen the hinges do bad and the lights stay on when they are closed.
  1. Battery drain issue
    By Coneklr in forum Chevy Silverado Forum (GMC Sierra)
    Last: 08-07-2013, 08:11 AM
  2. 98 Z71 battery drain problems
    By Aftershock77 in forum GM Electrical Tech
    Last: 05-28-2012, 01:47 AM
  3. Overnight Battery drain.
    By Joshua P. Weigum in forum GM Electrical Tech
    Last: 11-12-2011, 07:41 PM
  4. 08 Silverado battery drain
    By GrayGhost63 in forum GM Electrical Tech
    Last: 02-08-2011, 01:42 PM
  5. battery drain but test shows no drain???
    By rondo in forum GM Electrical Tech
    Last: 09-12-2010, 11:54 PM
