Results 1 to 2 of 2
    Default 03 avalanch put it on scanner because 3rd and 4th r missing when going down the road
    drained tranny pan and changed tranny filter, it looked like alot of metal
    03 avalanch put it on scanner because 3rd and 4th r missing when going down the road it wont engage unless you get the truck up to high revs and high speed {feels like slipping}
    it comes up with mass airflow sensor codes
    on a genisys otc scanner
    1 of the of the fast trac repair fix statements on genisys scanner , says the mass airflow sensor could make it slip in 3rd and 4th because its not getting the engine revs
    {motor will peak with pedal held down}
    any suggestions besides bringing to the shop {i work on vehicles}
    all fuse`s seemed to be good ,the 1`s that have power with key on
    I think they are completely separate issues, especially as you have metal in the tranny drain. The tranny problems could be tricking the PCM into thinking there is a problem with the MAF
    However, go ahead and fix the MAF and see if that cures the tranny problem.
  1. Can OBD II scanner read OBD I ????
    By ejohnson03 in forum General Chevy & GM Tech Questions
    Last Post: 12-24-2011, 04:01 PM
  2. Which Code Scanner?
    By joetom5 in forum General Chevy & GM Tech Questions
    Last Post: 02-21-2010, 03:42 PM
  3. Road Testing the Rocker Pods - Blog Update - First Road Trip
    By Springthing in forum Ultimate Truck Gear
    Last Post: 11-12-2009, 08:21 AM
  4. OBD I scanner
    By ct9a in forum General Chevy & GM Tech Questions
    Last Post: 07-02-2008, 04:46 PM
  5. F/S Radioshack PRO-94 Scanner
    By MD4x4 Fireman in forum General Classifieds
    Last Post: 01-31-2008, 09:21 PM
