    Default 89 2500 Sub sputters & dies under load - 350 small block
    I dont know what has happened during my tune up.The motor will idle & rev in neutal all day, but when i put it in gear & go to accelerate it starts backfiring & will cut off sometimes.
    here's what I did this morning as a simple tune up:
    changed spark plugs to stock ACDELCO, same plugs that were in it.
    changed distributor cap & rotor, same cap & rotor style that were in it.
    changed spark plug wires, did one wire at a time to make sure I didn't mess up firing order.
    changed ignition coil to MSD ingnition coil
    changed air filter
    I've checked the firing order twice, it right.
    I dunno what the heck I did, any help is very much appreciated.
    Vaccum leak?...my brother-in-laws truck is a '96 chevy and his would do the same thing...found out it was a vaccum leak and all is good now!...just throwing that out there
    Line-X'd Bed
    5.3L Flex Fuel
    Factory Black Running Boards
    2" Rough Country Leveling Kit
    EGR In-Channel Vent Visors
    Exterior PLUS Package
    Interior PLUS Package
    K&N Drop-In Air Filter
    Bowtie Mud Flaps
    Cat-Back Dual Exhaust
    Black Bowties
    DeeZee Toolbox(Debadged)
    ProFlaps
    Towing Mirrors
    Next Planned Mods
    Bigger Tires
    Aftermarket Rims
    I'll check the vacuum lines again. Thanks.
    No, they all seem to have a good seal. As far as which hoses, I've checked all the hoses coming out of the throttle body.
    The problem may not be as severe as I originally listed. Sometimes the truck with back up the driveway, pull out the subdivision. But will start sputtering & backfiring when I get on the road. It seems to lose power & dies sometimes. I have to limp it back home sputtering & moving slow. I'm stumped...
    Oh and I must add the truck ran ok before my tune up. I drove it an hour and a half from where I bought it without a problem prior to the tune up
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    There are some combinations of miss wired plugs that will run and exhibit the symptoms you describe. There are aftermarket caps that look EXACTLY like stock but have an internal wiring scheme that allows the plug wires to be routed so that they do not cross over each other. Make sure the firing order matches the cap you have.
  1. 89 c6000 small block to big block engine swap
    By chapman1200 in forum GM Powertrain
    Last Post: 05-25-2012, 09:28 AM
  2. '88 Blazer sputters and misses under load
    By flatearthling in forum Chevy Blazer Forum (GMC Jimmy)
    Last Post: 08-04-2011, 02:12 AM
  3. 1996 Silverado Spits and Sputters under load?!?!?
    By Rbernsdo in forum General Chevy & GM Tech Questions
    Last Post: 10-23-2010, 11:37 AM
  4. '02 Suburban dies under load / power
    By kbroderick in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 10-21-2010, 10:40 AM
  5. '02 6.0 2500HD Dies Under Load
    By Xyclone in forum GM Powertrain
    Last Post: 10-02-2009, 08:48 PM
