    Jr. Mechanic b-radical's Avatar
    Nov 2009
    San Diego, California, United States
    Default Moisture accumulating in parking lamp
    On my truck the passenger side parking lamp is somehow getting moisture in there. I've had the truck for a long time and never had a problem with this before. I tried taking it off and submerging it in water to find the leak, but didn't find anything. After that, I added a layer of RTV silicone to the rubber gaskets that seal the bulb connector with the reflector housing and it still gets wet in there.
    Any suggestions?
    2000 Silverado, 4.8L, LS
    3" Dynomax cat back exhaust
    Drop-in K&N air filter
    200 amp Nations alternator
    KYB GR2 Shocks
    Bluetooth OBD2 adapter with Torque App on Samsung Note 2
    Custom Stereo System l Pioneer/ Boss door Speakers l 1200 watt Performance Teknique amp l 1 farad capacitor l 2 12" kicker comp subwoofers
    Slider rear window l Locking tailgate, de-baged l 265/75/16 Bridgestone Dueler H/L tires l Fully synthetic oil l Tinted windows
    4l65e upgrades - five pinion planetaries l HD sun shell l high performance band
    You pretty much did what I would do. Check all the seals. It might not leak under the water do to the pressure. All it has to be is a needle size hole for the moister to get in not necessarily a leak. If you plan on keeping the truck for years to come, It is a must fix otherwise a lot of components will rust (bigger problems). At this point I would take off again and reseal ALL the seals or buy a used one. Since everyone are buying LED’s you might be able to find cheap.
    Tim Walters (Curky)
    I think a set of new lenses runs around $50. They are $44 here: http://monsterautoparts.com/CHEVROLE...ark_lights.htm
    I'm having the exact same issue on my truck but it's the driver's side parking lamp that has been collecting moisture. It has been collecting moisture almost since I got the truck (new in 2001) but it hasn't given me any problems apart from looking like crap. I'll look into it at some point.
    You can drill a small hole on the bottom of the housing and it will evaporate and not come back. Cheap fix and works every time!
  1. Black headlights+parking signal+smoke bumper fog lamp
    Last: 09-25-2012, 10:10 AM
  2. Replies: 0
    Last: 09-23-2012, 05:20 PM
  3. Black headlights+parking signal+smoke bumper fog lamp
    Last: 09-13-2012, 08:20 AM
  4. Gas Accumulating on Bottom of Tank - '99 Tahoe
    By cqlink in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 11-07-2010, 03:25 PM
  5. Moisture trap mod help
    By SomeBourbon in forum General Chevy & GM Tech Questions
    Last: 04-05-2010, 10:27 AM
