Thread: Tire size
    Sep 2012
    COOKEVILLE,TN
    Default Tire size
    Hey Guys,
    I'm a new Suburban( used ) owner, black '97 3/4 ton, 4x4, 454, 3.73 gears with a 2" body lift. The guy I bought it from put the stock tires & wheels ( 8 lug/16 inch ) back on it. I was wondering what size tires would you guys recommend. The stock ones look tiny. I have an old '75 Blazer with new 33/11.5/15 on it. I thought about getting 8 lug/15 inch wheels, somebody said they will not work. Thanx ! 97 in 10EC
    33's would look good. I am not sure on the rim size. I know that at least as of 2000 15's would not work as the caliper was in the way (16 was minimum).
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    they might fit. I had 15's on my 95 silverado
  1. Replies: 2
    Last Post: 11-29-2010, 04:58 PM
  2. tire size
    By 06piney in forum Wheels & Tires
    Last Post: 03-23-2009, 05:44 PM
  3. Tire size
    By IRONHIDE in forum Wheels & Tires
    Last Post: 05-11-2008, 07:48 PM
  4. tire size and tire availability
    By Leonard in forum Wheels & Tires
    Last Post: 08-18-2007, 11:02 AM
  5. 1999 k1500 ls tire no lift max tire size.....
    By ultramegabob in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-17-2007, 11:35 PM
