    Exclamation change oil light
    i have a message center in my truck that reads change engine oil which i did but cant figure out how to get this notification off. i do not have my manuel so i was wondering if u guys could tell me how to do this? thanks
    99 chevy 1500 silverado 4.8 vortec True 2.5' dual exhaust with 3' Silver vein tips and vx muffler, 2005 tail light swap, mb tko 16" matte black rims Upcoming mods:HID headlights, 2" leveling kit
    Turn the key to the run position but do not start the engine. Slowly press the accelerator pedal to the floor and release 3 times. Your message center will indicate the oil life monitor has been reset.
    x2 on what @moogvo said. But, I think that it has to pressed 3 times within 5 seconds.
    You're right, it is 3 times within 5 seconds.
    2002 Chevy Silverado & 1995 Ford Bronco
    02 Silverado: 50K miles, 20" Motto Rims, Flowmaster 50 Series
    95 Bronco: 160K miles, 4" Superlift, 33/12.5/15 Mickey Thompson
    01 Civic: 75K miles, DD
    -Erik
    Yes, that is the case. I didn't think about that... I am just used to doing it now. LOL!
    ok ill try it. so does it take time for it to turn off or it just does automatically?
    if you have buttons on the steering wheel i believe it can be reset this way aswell, as my change oil light is on aswell im gonna run out n see if i can get it to go out.
    ignition on throttle pedal to the floor 3X in 5 sec. then the light will flash and its reset.
    10 sec. total time.
    thankks guys it worked
    Apr 2009
    Not sure if it does it to anybody elses truck, but mine will tell me that the oil life has been reset upon start up for several start ups, post reset. It has done it since about the 5th oil change I've done. Not a big deal because it does eventually go away.
    Also, don't rely on that "Change Engine Oil" to change the oil. 3-5,000 miles is recommended. I let my truck go all the way to the next time that prompt came up once, and it was about 8,000 miles after I changed it the last time.
    2005 Chevy Silverado W/T
    Planned mods not in order
  1. Marker light Change
    By peterjame in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 07-28-2011, 01:37 PM
  2. Change Oil Light
    By My99Silverado in forum General Chevy & GM Tech Questions
    Last Post: 07-26-2010, 10:00 PM
  3. Change oil light is on
    By mvince20 in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 01-24-2010, 12:54 PM
  4. Change Oil Light
    By mowerboy1000 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-10-2007, 04:20 PM
  5. oil change light
    By 06z-71 in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 02-19-2007, 12:46 PM
