GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Excessive Noise
  1. #11
    Sr. Apprentice
    Dec 2010
    Groton, Connecticut, United States
    Got the new bearings, installed them. Now the truck is back up and running. Got a new question though...steering feels loose now, I replaced outer tie rods a couple years ago, got the alignment done, and haven't touched it (except for driving when everything went downhill. Any suggestions on what to look at today?
  2. #12
    check your stearing gear and your idler arm, i know that what is wrong with mine.
    1994 GMC Yukon, 2 door, Victory Red
    Garage Link: http://www.gmtruckclub.com/forum/sho...1994-GMC-Yukon
  3. #13
    Legend
    Sep 2010
    everett, massachusetts
    with one front wheel off the ground move the wheel in /out to observe any steering joint movement.
    when greasing these joints look for rust and water to come out / seals broken this would indicate a wear issue.
    the idler arm moves up/down more than 1/8 in then the arm is too worn.
    It is possible the toe alignment is not correct. if the wheels are not adjusted to be in slightly the vehicle will have a wandering effect. too much toe in will cause the outer edge of the tires to wear more than the rest of the tire.
  4. #14
    Sr. Apprentice
    Dec 2010
    Thanks everyone. I'll take a look shortly, and see what I can find!
Similar Threads
  1. Excessive Cab Noise - 2010 Chevy Silverado & 2010 GMC Sierra Road Noise
    By Hawgin1 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-08-2014, 02:56 PM
  2. 5.3 excessive oil use
    By nightscape in forum North America - Canada
    Last: 09-28-2010, 07:02 AM
  3. excessive background noise from cb
    By 96Z71 in forum Audio, Video & Gadget Tech
    Last: 03-08-2009, 05:57 PM
  4. 4wd excessive noise
    By jdixon in forum GM Powertrain
    Last: 12-22-2008, 06:44 PM
  5. Excessive Wind Noise
    By Tom Evans in forum GM Powertrain
    Last: 09-04-2007, 12:09 AM
