Results 11 to 14 of 14
Thread: Excessive Noise
    Dec 2010
    Groton, Connecticut, United States
    Got the new bearings, installed them. Now the truck is back up and running. Got a new question though...steering feels loose now, I replaced outer tie rods a couple years ago, got the alignment done, and haven't touched it (except for driving when everything went downhill. Any suggestions on what to look at today?
    check your stearing gear and your idler arm, i know that what is wrong with mine.
    1994 GMC Yukon, 2 door, Victory Red
    Garage Link: http://www.gmtruckclub.com/forum/sho...1994-GMC-Yukon
    with one front wheel off the ground move the wheel in /out to observe any steering joint movement.
    when greasing these joints look for rust and water to come out / seals broken this would indicate a wear issue.
    the idler arm moves up/down more than 1/8 in then the arm is too worn.
    It is possible the toe alignment is not correct. if the wheels are not adjusted to be in slightly the vehicle will have a wandering effect. too much toe in will cause the outer edge of the tires to wear more than the rest of the tire.
    Dec 2010
    Thanks everyone. I'll take a look shortly, and see what I can find!
  1. Excessive Cab Noise - 2010 Chevy Silverado & 2010 GMC Sierra Road Noise
    By Hawgin1 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 12-02-2013, 12:34 PM
  2. 5.3 excessive oil use
    By nightscape in forum North America - Canada
    Last Post: 09-28-2010, 07:02 AM
  3. excessive background noise from cb
    By 96Z71 in forum Audio, Video & Gadget Tech
    Last Post: 03-08-2009, 05:57 PM
  4. 4wd excessive noise
    By jdixon in forum GM Powertrain
    Last Post: 12-22-2008, 06:44 PM
  5. Excessive Wind Noise
    By Tom Evans in forum GM Powertrain
    Last Post: 09-04-2007, 12:09 AM
