Results 1 to 10 of 12
    Default What would be involved in installing some 11R22.5 tires and 22.5 inch rims on a
    What would be involved in installing some 11R22.5 tires and 22.5 inch rims on a 2000 silverado 1500 / 2wd? is it even possible? or whould it ruin the transmission?
    Jr. Engineer Jaele's Avatar
    Nov 2011
    Fairfield CA
    Is this a real post or am I just to drunk?
    2011 Silverado 1500 Z71 4x4 Crew Cab
    LED Dome light
    LED Floor lights
    RC Leveling kit
    Tow Mirrors Custom LED running/signal lights
    BakFlip G2 Tonneau Cover
    Are you looking into a set of Semi wheels for a 1500?? A friend had them on his HD and it Looked very cool I will try to find a pic.. But a 1500 I don't know.....I would not do it..
    why would you want to? not only do they use a completely different lug setup (10 bolt) they are far heavier, clearance issues everywhere, and tires are really expensive. i could maybe see it on a lifted one ton or something, but those trucks are built car heavier, a 1500 just could handle the stress involved. there is a reason those rims are on semis and the like.
    Alex
    Quote Originally Posted by Jaele View Post
    No, your not drunk and this is a real post I have seen a number of 3500/350's where it has been done. I have seen stupid(er)not a real word; things done to trucks before.
    Yes, I have seen a number of 1 ton/ 3500's/F350's where they have done this and I really like the look if gives. I assume that the tranny and axles on a 1500 would get destroyed (stock) trying to use that tire and wheel combination.
    So it could potentially be done, but it would require more than wheels, tires and a lift kit........ a new tranny and axles would be needed to.
    Quote Originally Posted by Sierraowner5.3 View Post
    Alex
    Not sure how much more of a clearance issue I would have over the clearance issues I have now with a stock height 1500, it would probably sit a tad higher that it does now.
    The cost of tires is relative...... My 265/70R16 Michelin LTX M/S2 were $189 each....... People with lifts that use nitto grappler's are sitting at 35 inches (road to top of tire). This would not be any different.
    Also the nitto's are almost $400 each ($391). 11R22.5's run between $250 and $300 per tire.
    So if I want to use these:
    http://www.americanforcewheels.com/
    on a 1500, I assume, I would need to upgrade to an HD Transmission (4L80e/gas) or the allison (diesel). The drive shaft would need to be upgraded. I could go with a 3500 HD axle in the back, a lift kit and heavy duty suspension in the front to support the weight and clearance of the new wheels.
    Those wheels are heavier than the stock wheels on a 1500, but they are lighter than the steel wheels on a semi.
ID:	44798Click image for larger version.
ID:	44799Not my friends but some pics for you..
    I did some research because I had no idea what you were talking about. Those tires measure 41.4" in diameter. That is going to take alot of work to pull off. I had a 95 silverado with a 6" suspension lift and a 3" body lift. I could only fit 38.5" tires
    Lol, That is sort of the look, I have seen them on duallys that are not lifted quite that high where they "look" stock and throw you off so you have to do a double take. That truck they stand out easy because of its height and the color (Yellow?) :-( lol
    The paint on this one is not so obnoxious and it visually does not seem quite as high:
    http://www.americanforcewheels.com/i...m&path=9&aid=7
    I have been searching for "the look" I want:
    http://www.playingwithspeed.com/page4.html
    I don't think that looks all that crazy, it actually looks good, but doing it on a 1500 is a whole other story :-(
    I found a pic of my friends truck.. He used to Fishtail it.. It was Whicked Fast...
  1. Replies: 6
    Last: 06-02-2011, 03:27 AM
  2. Replies: 6
  3. 22 inch Rims and Tires
    By Ramdavis in forum Wheels & Tires
    Last: 05-11-2011, 09:52 AM
  4. 22 inch Rims and Tires
  5. Vibration after installing new rims and tires
    By bob13 in forum Wheels & Tires
    Last: 05-01-2009, 07:42 AM
