Results 1 to 1 of 1
    Default power steering pump rebuild kit
    After my hydro booster was replaced (twice) my power steering pump is noisy. It drives me nuts. I am looking at buying a new one. But I have come across some rebuild kits at a quarter of the cost. Has anyone used these? They do not include any bearings in the kit. Just a shaft bushing, orings, and a seal. I am concerned that if I use a kit the noise will still be there. Are these kits primarily for leaking pumps? Thanks for the advice in advance. Added: I will not buy an aftermarket rebuild pump as I just went through six reman alternators in one month. (bearings bad in all of them but one, that one did not put out any voltage). I can get a new pump from GM for $93 with the core charge using an employee parts program. OR I can get a new one, same part number on amazon for $73. It concerns me that the seller on amazon is selling it for less than what I can get it for through SPO. (Fake??)
  1. power steering pump
    By ericz in forum General Chevy & GM Tech Questions
    Last Post: 05-20-2012, 08:12 PM
  2. power steering pump going bad?
    By pipe539 in forum General Chevy & GM Tech Questions
    Last Post: 07-10-2011, 03:23 PM
  3. Power Steering Pump
    By Bryan in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 02-13-2010, 12:22 PM
  4. Power Steering Pump?
    By blueZ71 in forum GM Powertrain
    Last Post: 03-20-2009, 10:03 AM
  5. power steering pump problem
    Last Post: 04-14-2007, 11:18 PM
