    Default Squeaking problems
    I have an 08 silverado 4wd reg cab. i had a rough country front end leveling kit installed in july. ever since then there has been a squeaking and creaking noise coming from the front when turning and normal driving. also recently when i go in reverse there is a loud squeaking noise that is just embarrassing. does this have to do with the leveling kit? should i remove it? or does something need to be greased to stop this? please help
    Check your u-joints for the noise in the rear. I am not familiar with that kit, but I would go ahead and grease all the zerks in the front (ball joints, tie rods, idler, pitman) Then I would spray some lube on the control arm bushings and see if that helps.
    Yea I was finally able to get it to the dealership and they said the u joint went out and while I was there he said I had 3mm left on breaks so perfect timing I guess but thanks for the help
  1. 1998 S10 Ext Cab Squeaking from under cab.
    By Fusefinder in forum Chevy S10 Forum (GMC Sonoma)
    Last: 12-04-2011, 03:26 AM
  2. Brakes squeaking on my 08!
    By cliff08chevy in forum Lifted & Offroad Suspension
    Last: 07-10-2010, 07:28 PM
  3. Squeaking, maybe from suspension?
    By Crakums_GT in forum Lifted & Offroad Suspension
    Last: 07-28-2009, 07:30 PM
  4. Squeaking Noise
    By SnowmanZ71 in forum GM Powertrain
    Last: 04-29-2009, 03:48 PM
  5. squeaking noise?
    By stangboy in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-01-2008, 03:32 AM
