    Default 2003 Yukon Denali XL Acceleration problems
    Hi everyone, I'm new here so pardon me if I'm posting in the wrong place. I recently purchased a 2003 Yukon Denali XL 112k miles. The truck has minor acceleration issues. From a stop or a low RPM, when I go to accelerate slowly, I can hear a buzzing sound from under the drivers feet area, almost like a loud electrical noise (naturally I'm thinking APP sensor, but I'm not sure if the noise is from the outside or the inside). And the car does not go. If I let go of the gas pedal and reapply, then she goes. Power above 2000 RPMs is good. I'm quite experienced with engines, but I've never seen this before. And this is an intermittent problem, so it makes it even more difficult to diagnose. There's no check engine light. When I first got the car, I replaced the MAF sensor and the Throttle Body. The fuel filter has been replaced, and the air filter is clean. This particular Yukon is not equipped with an EGR valve.
    So with all that said, Any pointers would be greatly appreciated...And thanks for reading.
    Default Solution
    To follow up on my post, my diagnosis took me to the ABS wheel sensors. It was misreading wheel speed leading the computer to think that the car lost traction, thus engaging the Stabilitrak Traction Control feature. In turn, that reduces engine power, and makes a weird noise (Almost like a loud electrical noise) under the car. So it makes you think that the car is bogging. When this happens, pay attention to the DIC, the "Traction Active" display will come on for a short time. (If you're not watching it, you'll miss it).
    Now, The Repair...
    A good cleaning of the rust on the hub where the sensor attaches to it should do the trick. If you want to go nuts. Amazon has the new sensors for dirt cheap. 50 dollars for both sides. Do remember that the left and right sensors are not quite the same. The Part numbers are AC 19181872, and AC 19181873. Good luck, and I hope I was able to help someone.
    Glad to see that you were able to find the issue.
    Quote Originally Posted by sandstorm View Post
    Now, The Repair...
    I am experiencing the exact same issue on my 2004 Chevy Tahoe LT w/Stabilitrac. I have heard that the proper way to resolve is to replace the entire Wheel bearing & Hub assembly (including ABS sensor). Does anyone know if there is a good way to determine the parts needed and if there is a difference in Wheel Bearing & Hub assemblies that you may be able to purchase from 1A Auto part #1ASHF00005 $65.
    Thanks!
  1. 1999 Yukon 4x4 difficult to start and bogs on hard acceleration
    By bigdave367 in forum Member Introductions
    Last Post: 11-01-2011, 08:10 AM
  2. Acceleration problems
    By moxiep3 in forum Chevy Blazer Forum (GMC Jimmy)
    Last Post: 08-23-2011, 03:39 PM
  3. couple problems with 04 Denali xl
    By Z-burb in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-08-2009, 12:39 PM
  4. Yukon XL or Denali?
    By tlperry68 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 06-26-2009, 07:55 PM
  5. '03 Yukon Denali
    By Jeff in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 05-04-2006, 07:06 PM
