Results 1 to 10 of 11
    Sr. Mechanic
    Jun 2011
    Tuscaloosa, AL
    Default BlackBear Data log
    Okay some of you guys that have blackbear maybe able to answer this, after logging I noticed my max torque was only 324Lbs. These trucks are rated for 360 and then with my mods I was thinking maybe 370. Why did I get such a low number?
    2004 GMC Sierra SLT 6.0L 4x4
    UWS Low Profile toolbox 10% tint front and over stock back tint
    AirAid MIT and K&N airfilter
    BlackBear Performance
    What's the RPO code for your engine?
    Sr. Mechanic
    Jun 2011
    Tuscaloosa, AL
    The RPO code is LQ4
    Stock rating on the LQ4 seems to be 360-370 lb-ft at the flywheel. Note that the data logging is more than likely calculating power based on vehicle speed vs. engine speed, which would mean you'd be getting an approximate number for power at the wheels. Given a 15-20% loss through the drivetrain after the flywheel, I'd say the number line up ok, and you're probably making ~380 lb-ft at the flywheel.
    Sr. Mechanic
    Jun 2011
    Tuscaloosa, AL
    Oh okay I know what you're saying. I was curious too because my friend has the same truck except 2 years older and he only put out 310. Well thanks for the info I can't wait for the tune to get here!
    Sr. Mechanic
    Jun 2011
    Tuscaloosa, AL
    hey guys I have the new pcm in and damn I can definitely feel the difference. Does anyone now how accurate the readings on HP and Torque are when logging data? Cause if it is then I am putting out some pretty good numbers
    what are you using to log your data?
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    Sr. Mechanic
    Jun 2011
    Tuscaloosa, AL
    the device from blackbear
    maybe because your doing the mail order tune?
    or is that something your just logging for yourself to just keep track of things?
    i did my tune in person, and for some reason Justin was not able to give me a readout of my horsepower and torque, the only two pieces of information i crave to know to this day.
    Sr. Mechanic
    Jun 2011
    Tuscaloosa, AL
    It was one of the parameters to choose from so I figured it should read correctly since it's reading everything else
  1. 4.3l engine data and help on diagnosis.
    By randyr8845 in forum GM Powertrain
    Last: 07-01-2012, 12:44 PM
  2. Data gathering for regearing -- some assistance?
    By SurrealOne in forum GM Powertrain
    Last: 11-27-2011, 03:26 PM
  3. MAF reading 0 g/s on data list???
    By 10mmguy83 in forum General Chevy & GM Tech Questions
    Last: 02-16-2011, 11:10 AM
  4. Chevy Truck Dimensional Data
    By psychotrshman in forum Chevy Truck Tech Forum
    Last: 11-12-2010, 12:11 PM
  5. Tire Diameter and fuel data
    By buckeyesalt in forum General Chevy & GM Tech Questions
    Last: 07-24-2009, 05:39 PM
