    Default Help with aiming headlights ~ GMC Yukon XL
    I bought a set of GM OEM Denali headlights for the yukon xl today. I installed them and am attempting to get them aimed properly. I know @SurrealOne has done this with his lights. (No LMGTFY please Surreal!) I did google it and that is how I came to this point. Here are my questions, How do I know what height to set them at as a baseline? How do I know that they are at the correct angle (left and right) I don't want to blind other drivers but if they are to low then I am losing out on distance. I put them in and pulled up to the garage door. I made sure the cutoff was even for both lights. I then put piece of tape at the top of the cutoff. Then I put a piece of tape 2 1/8" below that piece. I backed up 25 feet and the cutoff hits right at the top of the lower line. Perfect as DOT specifies a 2.1-2.5" drop over 25 feet. But, if my base height is incorrect then it is all off anyway. I also noticed at 25 feet the cutoff does not line up perfectly like it did at 1 foot. the drivers side cutoff seems to slant down toward the passenger side a small amount. I have not messed with the other adjuster because I have to take them in and out every time and did not have time tonight. Any help would be appreciated! Thanks
    Thanks @SurrealOne . That is much better than the crap I found searching google.
    It's the first thing that comes up when one searches for 'how to aim headlights' and yes, it's thorough -- but Popular Mechanics' stuff usually is. This begs the question of what the heck you were searching for...
    lol! I have no idea. Apparently I was drunk. Which is odd because I did not drink at all that day!!!
    Methinks I should have responded with another lmgtfy link, initially.
  1. Aiming Headlights
    By PantheraUncia in forum The Coffee Shop ~ Chit Chat
    Last Post: 07-29-2012, 11:24 PM
  2. head light aiming
    By chevyguy1414 in forum Lighting Discussion
    Last Post: 08-11-2011, 01:27 AM
  3. Headlight aiming, 1999 Yukon
    By mastersniper in forum Member Introductions
    Last Post: 08-31-2009, 10:47 AM
  4. Re-Aiming Headlight
    By kbuss in forum General Chevy & GM Tech Questions
    Last Post: 08-29-2009, 10:42 PM
  5. aiming fog lights??
    By kwconch021 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-15-2009, 07:29 PM
