    Default 2006 Suburban LTZ - Rumbling noise 35~50 MPH
    Hello,
    I have a 2006 Suburban LTZ with the 5.3L Vortex engine and off road package. It has 100K miles. I have done all regular maintenance at local Chevy dealer. Just did 100K tune up. Trany flush / maintence at 60K, etc. When driving after the warm up we get a supradic rumble that seems to come form engine compartment. This is not constant but seems to occur when driving in local traffic not highway at speeds between 35~50. RPMs are typically low 1500 RPM and usually when feathering gas as in constant moving traffic situation. I'm thinking it may be a speed sensor but dealer stated there has not been many problems with tranny on 2006 model. No idiot light indications either.
    Any thoughts appreceated
    Thanks
    Mark
    Venango PA
    Welcome Mark, perhaps a pulley, or a belt driven device under the hood. Idler pulleys and belt tensioner pulleys are a common failure item. Try takeing the belts off and turning the different pulleys by hand, see if any sound/feel rough.
    It could also be a tire with a broken belt.
    Hi Ray - Thanks for the guidance.
    I'll try the pullies to see what happens. Just had 4 new sneakers put on, Cooper discovery H/T's so probally not that. I guess the other thing I should mention is that I did have front end alignment because it was tracking left significantly. Even after alignemnet still not perfect but much better.
    Thaks again!
    Mark
    Don't completely discount the sneakers, I've had brand new one with belt problems. I don't think it happens very often, but it is a possibility.
    I too have had brand new tires that had bad belts. They replaced 2 on my wifes torrent after 6 months because the would howl at highway speeds. I would make sure that you checkout the ac compressor when the belts are off. Some compressors will make the noise that you are describing when they engage ans disengage. That would explain why you only hear it at slower speeds. After having my 2003 yukon xl for 3 months I finally figured out that the ac was always on unless I pressed the snowflake button. Then a icon with a snowflake with a line thru it would show up on the HVAC control. Before I discovered that I would here that compressor kick on and off constantly. It was the first and only GM vehicle I have owned that had a default mode with the AC on.
  1. Rumbling/groaning
    By jay2dc in forum Chevy Equinox Forum (GMC Terrain)
    Last: 12-15-2011, 11:09 AM
  2. 2006 silverado 5.3L hissing noise when reving
    By Jimbo3 in forum General Chevy & GM Tech Questions
    Last: 02-02-2011, 09:07 PM
  3. 2000 Chevy Silverado 1500 4X4 rumbling noise coming from front of truck! Help me
    By Chevytruckgirly in forum General Chevy & GM Tech Questions
    Last: 01-06-2011, 11:32 AM
  4. 2006 Suburban-Power steering type noise when on the gas
    By Gsquared in forum General Chevy & GM Tech Questions
    Last: 03-03-2009, 03:49 PM
  5. 2006 Equinox ABS noise
    By Wilj in forum General Chevy & GM Tech Questions
    Last: 09-24-2008, 12:39 PM
