    Default silverado alternator swap
    hello i recently got a HO alternator from a friend that came off a wrecked S10 it had a single wire pig tail that is the same style as the one on my 2001 silverado it bolted right in with minor modifications when i started my truck it only read that it was charging at 12 volts. I was informed that the s10 and has a internal voltage charging regulator and the silverado has a external regulator which may be the cause of why the HO of the s10 is not triggering a charge has anyone ever done a conversion like this or know of a bypass to trigger the internal regulator?
    Master Mechanic
    the silverado has an internal regulator/diode assy. what is the cause of this problem would be the small wires connector at the rear of the alternator that interfaces with the pcm of your vehicle.
    the silverado comes with the 105 or 13OAMP ALTERNATORS. both are interchangable.
    thanks for the reply I understand the concept if i were to install a dual alternator set up and run the HO output on a separate system would the PCM still conflict with the alternators output?
    Master Mechanic
    installing another alternator would be alot of work. having an altrnator that does not require any external control input and having the 12 volt output go to a audio power amp only or some other device would work. just keep them separate . make sure the ground is at the same place. use a separate battery for this 2nd alternator.
    on my boat I removed the troublesome 12 volt generating system[no alternator] and installed this type alternator.
  1. Alternator NEW NATURAL Chevrolet Silverado 1500 PART
    Last Post: 12-05-2011, 06:40 PM
  2. Chevy truck c k silverado high output alternator 05 06
    Last Post: 12-12-2010, 11:00 AM
  3. NSA ALTERNATOR chevrolet SILVERADO 1500 HD 03 05 part
    Last Post: 05-27-2010, 05:51 PM
  4. NSA ALTERNATOR chevrolet SILVERADO 1500 HD 01-02 part
    Last Post: 03-18-2010, 09:10 PM
  5. Roadside Alternator Swap!
    By unplugged in forum GM Electrical Tech
    Last Post: 11-24-2007, 12:17 AM
