    Default changing front shocks no wheel removal ? 2000 1500 4x4
    can i change my front shocks without removing my wheels looks possible any help would be appreciated changed back last week no problem truck only has 12000 miles on it rear shock seal got dry rott and went dead dont want same on front truck was never used sat for a few years
    Quote Originally Posted by bronx boy View Post
    I am not an expert so I would double check, but as long as the front wheels are on jack stands and off the ground I don't see why not. Taking the wheels off would just make it allot easier. ( Double check with someone though).
    since this has not been used much If a rust belt vehicle I would remove the front wheels clean any rust off the brakes,inspect front end components, etc. then replace the shocks with the vehicle lifted slightly to make the shock install easy . grease all the front end joints with a lithium grease.
    replacing the rear shocks with no lifting/wheel removal is possible because your not near any components.
    did the grease when i got the truck nov 2010 with 8400 miles on it also had all brake lines replaced my friend gave me this truck it sat so much he replacer all rotors and brakes at least twice in past ten years they just rusted to crap but thank god the body is perfictand interioralso tires went bad dry rott replced them last week.every told him to use the truck butt he is thick headed got the truck for free not bad if its for free its for me. will opt to do front shocks the right way next weekend will take off wheels
    i replaced my front shocks without removing the wheels. piece of cake!
    2000 1500 2wd
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    I did them on my 02 2wd, my 03 4wd and 05 4wd with the wheel on with no problem. 15-20 minute job.
  1. 2000 Tahoe 4WD front right wheel bobble over bukps
    By mcerreto in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 09-02-2012, 01:55 PM
  2. Front Differential install help on a 2000 Chevy Silverado 4X4 1500
    By Chevytruckgirly in forum GM Powertrain
    Last Post: 01-10-2011, 03:24 PM
  3. Changing wheel studs...Help.
    By gfam in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-30-2009, 08:40 AM
  4. Changing the driveshaft on a 2000 Sonoma
    By jgooder in forum General Chevy & GM Tech Questions
    Last Post: 11-17-2008, 05:09 PM
  5. free fix for steering wheel clunk on 2000-2004 1500-series
    By DutchTBI in forum General Chevy & GM Tech Questions
    Last Post: 02-11-2008, 05:36 AM
