    Default Paring brake indicator light.
    Hello out there, I am new to this forum so here is some details.
    I currently own a 2006 GMC Yukon SLT with the 5.3L.
    My problems is the parking brake indicator light comes on intermediately along with the chime.
    I have verified the parking brake itself and fully releases when needed( I always use the P/B, so seizing up is out of the question), the level of the fluid and have had the truck on a hoist at a friends garage to check for leaking lines or calipers. I have tried unplugging several of the braking system sensor but have had no luck figuring out this problem.
    If anyone out there could point me the right direction it would be greatly appreciated.
    P.S. I have filled out some info in my profile but have not had the chance to upload all the pics of my black beauty.
    Eric
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    Welcome to the forum. It may be that the parking brake switch needs to be adjusted. You may be able to check it next time the light comes on by lifting the E brake pedal with your foot or just lightly depress it an eighth to a quarter inch to see if it is very sensitive to pedal position.
    Thank you for the info. I have tried that exact testing method and the e-brake returns to its return position correctly.
    Quote Originally Posted by ericmondor View Post
    I think what dpeter was suggesting, was not a check of the physcial return of the pedal, but a check to see if when returned, was there correct adjustment of the switch. Can you turn on the light by gently pushing the pedal a short distance.
  1. Air bag indicator light???? Chevy Trailblazer issue
    By SidecarMike in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 11-20-2011, 10:54 PM
  2. 4X4 Push Button Indicator Light Switch - How to Remove? 1999 Tahoe
    By cqlink in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 09-18-2010, 08:49 AM
  3. Shift Indicator Light is Out
    By oxyvbverkle in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-20-2010, 09:01 PM
  4. Do brake shoes have a wear indicator???
    By brtt485 in forum Lifted & Offroad Suspension
    Last Post: 06-11-2009, 07:58 AM
  5. 1991 3/4 ton burb paring out
    By bigL in forum IA - Iowa Chevy Truck Nuts
    Last Post: 01-01-2009, 11:01 AM
