    Default differential ratio
    I have a 1990 gmc sierra 4x4 ,Ive owned it a couple of years and afert having the transmission and transfercase rebuilt I just put it in 4wd the other day for the first time and realized my front and rear differential are different and the rear is pushing the front I need to find out the front end ratio for that model since changing threar would be easier than the front
    Welcome to the club, it's good to have you aboard. If you post this in the tech portion of the site you may get your answer quicker. Good luck.
    2002 Chevrolet Silverado Ext Cab 5.3 Liter / Automatic:
    Current Modifications:
    • Edge CS programmer w/Pod
    • K&N intake
    • Magnaflow exhaust
    • 2005 Tahoe grill with Grillcraft Stainless Steel SW series wire mesh insert
    • 2005 Tahoe Z71 valance under bumper with round fog lights
    • Recon LED Daytime Running Lights
    • Third Brake light is LED by IPCW
    • Tail lights are Spyder
    • Headlights are TYC
    • Front blinkers are Anzo LED
    • 6000K HIDs in headlights high beam, low beam and fog lights
    • LEDs everywhere else inside and out
    • Rear lights wired to work like the new Silverado with 4 tail lights, blinkers and brakes
    • Lowered 2" in the rear
    • Genuine GM 20" chrome wheels with 285-50-20 tires
    • Drilled and slotted rotors
    • Calipers painted to match
    • Kenwood DNX 6160 radio with Bluetooth, GPS, DVD, iPod, Back up Camera and satellite radio
    • 2 Cerwin vega amps "1400 watts total"
    • 2 - 10" Kicker subs in custom box under back seat.
    • 4 Infinity main speakers and 2 PB tweeters on front post
    • New custom paint job, Red Fire on Charcoal Gray
    "There's no fun in playing safe or by the rules, but it's not fun being hit by a semi-truck either."
    Moved to powertrain forum.
    If it's apparent that someone has changed one of the gears, then I would think the only way to be sure of the front gear ratio is to actually count it out, unless you have some good service records for the truck. Sure, you could check the RPO code in the glove box, but there is likely no way to know if that is still what is in the front end of the truck.
    To measure the gear ratio, jack up at both front wheels and at least one rear wheel. Put the transfer case in 4H and the transmission in N (with the stock thermoelectric center axle disconnect CAD, you will probably have to have the key on for this test, to make sure the CAD is engaged). Rotate that front tires through one rotation (make sure both tires turn together) while counting the number of rotations of the front driveshaft. The number of rotations of the front driveshaft is your gear ratio (about 3.5 rotations means 3.55 gear ratio).
    Reading @MrShorty 's answer, has me thinking; if you jacked up all four, marked the bottom of each tire, and started the engine, placed the trans into a forward gear and let the wheels turn a couple of times. you could be sure the gear ratios are different if the tire marks are no longer together (say, both are not at 3 o'clock).
    Note, you could do this with only one side in the air if you are sure the rear is not posi/locking
  1. Trying to get gear ratio
    By renchr01 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-24-2011, 02:09 PM
  2. What is my ratio?
    By kcfocus1 in forum GM Powertrain Tech
    Last Post: 09-14-2010, 09:05 AM
  3. Gear ratio
    By stringbender in forum General Chevy & GM Tech
    Last Post: 02-08-2009, 05:49 PM
  4. Differential Ratio
    By CarpenterGuy in forum GM Powertrain Tech
    Last Post: 09-22-2008, 06:16 PM
  5. Air to Fuel ratio
    By 94chevybowtie in forum Member Introductions
    Last Post: 09-11-2008, 05:38 AM
