Thread: Should I do it?
    Default Should I do it?
    I have a 2013 Silverado and I know that the parts are just wearing in (550 miles on it). I was going to run it for 1000 miles and then change the oil. Is this really beneficial or a waste of money. Just trying to get the most life out of the engine. Thanks.
    not really beneficial at all. do you know if it is full synthetic or not? if not, it would be beneficial to go ahead and swap to full synthetic
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    I have heard many different opinions of this. I have had some techs tell me to change it at 1,000 miles. They say that it cleans any metal out from the break in period. I have had some tell me to wait the full time, until the oil monitor is down to 15%, that the break in period metal (if any) is not an issue. I don't really know the correct answer. I would say that if you want to change it at 1000 miles for your piece of mind then do it. It is not hurting anything, just cost money. Are you going to run synthetic or conventional? I would recommend that you stick with the Ac oil filter no matter which oil you choose.
    This is what I have been told, too. I think it's just a tactic to get repeat stealership business at the service counter and that what's in the owner's manual is what counts. After all, there's pretty much always metal shavings somewhere in the engine and tranny, and it's sheer age, size, and volume that determine if it's a healthy or unhealthy amount.
    Do what the owner's manual says.
    Oct 2010
    Cobourg, Ontario, Canada
    Pikey....why do you suggest sticking withAC Delco filters?? Do they have more capacity or last longer....thanks for the info...Brian from Canada
    Silverado Crew.....4.8 L
