    Default Hello all brand new to forum help please
    Hello I have a 94 chevy z71 stepside with a 350 that i cant get to stay running unless I keep pumpimg the accelerator cannot hold at a constant place or cuts off. Any suggestions would be greatly appreciated
    when was the last tune up? Spark plugs, wires, cap, rotor, air and fuel filter? Can you drive it? does it do ok at higher speeds?
    clean you intake
    Also does it work better on a full tank? Fuel pump could be going out on you
    1995 Saturn Sw1 196K and counting
    2001 Suburban LS 150K and counting
    2004 MR2 Spyder 62K and counting
    2007 mini cooper S 60K and counting
    All new wires plugs ect, just installed motor from proffesional rebuild ran good 4 weeks ago when first put in now not so good no cant drive it at all wont stay running at all unless in neutural and reving it its almost like its getting too much fuel or too much air but im not sure
    Quote Originally Posted by seaark20 View Post
    Ok try disconnecting the battery for 15 minutes and resetting the ECU that could be some of it.
    Tell me when you are under throttle and you back off does it really want to die then? could be your EGR valve of something else with your intake.
    try the computer reset and see what happens
    What about your fuel filter? After the EGR that is where I would check next.
  1. Wax on Wax off ~ What Brand of Wax to use?
    By 2mOOn in forum Detailing & Truck Care
    Last: 04-18-2013, 01:43 PM
  2. Chevy Silverado Forum ~ Anyone know of a specific silverado forum?
    By kylegillean in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-20-2012, 05:19 PM
  3. Brand New to the Forum
    By Aunt Na in forum Member Introductions
    Last: 12-03-2010, 08:06 AM
  4. Brand new to the forum
    By arh14 in forum Member Introductions
    Last: 05-16-2009, 04:54 AM
