    Default alternator bearing
    uh-oh,
    just found out my alternator bearing is going bad, any recommendations???? (very squeaky, and high pitch squeal)
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    You did make sure by turning it by hand without the belt right? And they really don't sell alternator repair kits anymore so you may have to get a new alternator all together.
    yep, sure did, and i figured that time to upgrade anyway
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    There are still some re builders there. Search in your local area and see if you can find one. They might replace the bearings for $30. I have one right down the street from me. Be careful buying a new (reman) alt. I had a nightmare last month with mine. I have a "bosch style" on mine, finding one was a PITA. Then after I found one, I went through 6 in one month!! One most of them the bearings went out within a week, two of them did not put out proper voltage. I did not add the 4 that had bad bearings right out of the box and I would not put on my truck. There was also one with a cracked case right out of the box. I ended up spending the $20 more and bought a brand new Bosch
    sounds like you had quite the dilemma, glad you got it all worked out...
    ill definitely be looking for a more high output alternator from DC power engineering like Surrealone has
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
  1. Carrier Bearing
    By MTM in forum GM Powertrain
    Last Post: 02-01-2012, 07:16 AM
  2. Wheel Bearing 4x4
    By Niekamp-Alaska in forum Chevy C/K Truck Forum
    Last Post: 01-23-2012, 07:46 PM
  3. Bad Bearing
    By LB'07-Z in forum GM Powertrain
    Last Post: 11-14-2011, 08:05 AM
  4. Replaced Hub Bearing
    By BowTieFan1 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-29-2011, 09:19 PM
  5. A/C Clutch Bearing
    By SLCSubGuy in forum General Chevy & GM Tech Questions
    Last Post: 02-14-2008, 09:18 PM
