    Default 8.1L in a 1999 Suburban?
    Just wondering if anyone here ever swapped an 8.1 into the GMT400 body style. I know the 7.4 would be a pretty easy swap since its the same generation, but what about the 6 and 8.1? The 5.7 will haul my 5000 lb boat fine but she heats up after a while when going over 80. I was hoping it would be cheaper to buy a 6L or 8.1 and install heavy duty leaf springs than to buy a newer 3/4 ton. Also would appreciate if anyone with experience with all three engines (6, 8.1, 7.4) could lend me some wisdom about them. I know the 8.1 is a gas hog, but I'm averaging 12.5 with the 5.7 now so.....
    Thanks!
    Jake
    MONTANA CADILLAC
    Proper noun. Used to describe ones large, lifted, comfortable, gas guzzling SUV that is driven primarily in the backwoods. Synonym for Chevy Suburban/ GMC Yukon XL.
    One corporate Suburbanite says to the other, while sipping his overpriced latte, "Check out the hick in that Montana Cadillac!" Both giggle as they wait for AAA to come pull their Audi/ BMW/ Mercedes out of a snow filled ditch
    Any one of them would require getting a new tranny and drive shafts. It would be easier and cheaper to better cool your tranny and engine oil. Also why are you towing anything at 90?? Thats extremely unsafe. Yes the 7.4 would be fairly easy to swap in it would require switching engine mounts, upgrading to a 4L80e transmission, new tranny mounts, new front and rear driveshafts (if 4x4) because the 4L80e is longer and the 7.4 takes up more room. The 5.7 should have no problem with that size boat.
    Still better plan is better cool your tranny and oil plus you can add some aux fans to help cool the engine. In adding the fans you may need a bigger alternator, but still alot cheaper then having to get a whole new drivetrain.
    Towing over 80? Really dude? I tow a 30ft camper that weighs about 6500 loaded with my Burb and never go over 65. Most trailer tires are rated for 65mph....maybe you should check yours so you don't end up hurting someone.
    Quote Originally Posted by 98BIGBLOCKBURB View Post
    This is very true... Also pulling that much weight at that speed is just not safe...
    The 8.1 Sub's I think were built on a Truck frame not a 1500 frame so not an easy install.. Also 8lug not 6 so differant axels.
    Keep an eye out for a nice Red Cladded Avalanche with a Cowl hood. Thats Jake he lives in Rockaway also
    The 8.1 is not a great engine, the 6.0 has more useful power and torque band. You would be better off getting the 383 (it is designed for your truck and tranny)from GMPP and adding a shift kit for your current tranny. Why on earth would you drive that fast towing anything?
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Jr. Engineer Jamm3r's Avatar
    Dec 2012
    Minneapolis area
    Quote Originally Posted by '99Suburban View Post
    I'm assuming that your 1999 'burb is a 2500. That being the case you already have the 4L80e transmission so the 8.1 would bolt right up. Not sure about clearances or the PCM but the times I've thought about swapping my 5.7 for something bigger I've always presumed that the 7.4 is the way to go. The 8.1 has a fairly large oil cooler in front of the radiator that you'd have to shoehorn in somehow especially if you're having cooling problems already.
    Not sure that displacement will help with that, maybe adding some cooling to your 5.7 would though.
    I get 13 mpg with my 8.1 burb by itself. Towing at 75 mph I get 7 mpg but that's with an 8,000 pound trailer. I don't tow any faster.
    I like the 8.1. It churns out the ponies at lower RPM and makes for a smooth, quiet ride.
    Who knows? I don't judge anyone on speed alone. Some trailers can be towed safely at higher speeds depending on weight distribution, hitching, aerodynamics, brakes, and tires. I'm comfortable at 75 mph with a ProPride hitch, a MaxBrake controller, and suitable tires, and can stop from 75 in a straight line in the same space it takes to stop without the trailer.
  1. New HU for 1999 Suburban
    By snowbanks77 in forum Audio, Video & Gadget Tech
    Last: 01-28-2013, 01:59 PM
  2. Chevrolet : Suburban 1999 Suburban Monster Truck ~ 100k Invested
    Last: 06-30-2011, 11:49 AM
  3. Need to recarpet 1999 suburban
    By rangerone in forum Chevy Truck Accessories
    Last: 04-18-2008, 10:03 PM
  4. 1999 GMC Suburban 454 c.i. upgrades
    By gconste in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 02-14-2007, 08:28 AM
  5. 1999 GMC 4x4 Suburban SLT
    By cornboy in forum General Classifieds
    Last: 12-28-2006, 09:21 PM
