    Default Yukon Denali seat recline sensor location and adjustable pedal sensor location??
    My cousin has a 04 GMC yukon xl Denali. Her heated seats keep shutting off. After some research her husband believes that it could be the seat recline position sensor or the adjustable pedal position sensor. We can not find and diagrams or pictures that show the location of theses sensors! I know that @99'HEARTBEAT is a magician when it comes to this stuff, So I am counting on him and the rest of the membership to help me out. Any ideas? Thank you!!
    Mike....here are Diagrams of Front Seats for the 04" you've mentioned above,
    For the Driver Seat
    Number #3.....MODULE DRIVER/SEAT SI INFL RST,(W/HARNESS)
    Number #19....SWITCH DRIVER/SEAT ADJR,(6-WAY)(W/COVER)
    Number #29.....ADJUSTER DRIVER/SEAT,(INCLS 40),(INCLS SENSOR & MOTORS)
    Number #40.....SENSOR KIT INFL RST FRT PASS POSN,(PART OF 29),(INCLS RIVETS)
    Number #46..... HARNESS DRIVER/SEAT ADJR WRG
    The Passenger Seat,
    Number #52 is..... MODULE PASSENGER/SEAT SI INFL RST,(W/HARNESS)
    Number #12 is..... HARNESS PASSENGER/SEAT ADJR WRG
    Number #6 is:.....MODULE KIT INFL RST PASSENGER/SEAT SUPPRESSION,(INCLS 5,8),(INCLS PAD & SENSOR)
    Mike......hope these Diagrams can help you out???
    Last edited by 99'HEARTBEAT; 11-08-2012 at 03:20 PM. Reason: Added Infor.....Number #46 Added to the list.
    Thanks Mike! I knew that I could count on you!!
    Your Welcome Mike........
  1. Airbag sensor 1 location
    By Pikey in forum General Chevy & GM Tech Questions
    Last: 08-29-2012, 09:52 PM
  2. Knock sensor location on a 93 k1500 with a 5.7 litre
    By pook7one in forum GM Powertrain
    Last: 12-23-2011, 12:05 AM
  3. MAP Sensor Location
    By Metaluzc in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-12-2011, 04:45 PM
  4. sensor location
    By silverado28529 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-23-2010, 08:15 AM
  5. 2005 tahoe impact sensor location
    By caterpillarmx in forum General Chevy & GM Tech Questions
    Last: 10-15-2009, 07:05 PM
