    Default Battery question ~ 2000 Chevy Silverado
    Hey guys,
    So I finally went to the beach for the first time since getting my optima yellowtop battery, and was using my truck as the boombox(as usual) with the engine off. Well i noticed something VERY strange...
    Typically ill start my engine every 30 minutes or so just to be safe, and i did this as normal. I was playing moderately loud music for about 1.5-2 hours. Well with my typical batteries (NON AGM) (autocraft gold), if the battery is gettin low, obviously it will crank over a little bit slower, but if you watch the gauge, once the engine is running, it reads out anywhere between 13.8-14.4 volts. Well this time with the optima,(before leaving) i had my ignition on, but engine off, and i noticed the gauge was right above "12", so i though that was strange, but if i start it it will go back up to ~14.4 in a few seconds. So i started it and observed, it cranked over just fine, that the gauge stayed there right above "12", i let the engine idle for about 2 or 3 minutes and noticed it hadnt moved up at all. so i gave it a few steady engine revs, and little by little the gauge started moving up towards "~13 V". Very Very slowly. I continued with a few steady revs, and it went up a little higher, but right around ~13 V it wasnt going up much higher at all.
    So my friends and I were leaving at this point, and i figured driving back 5 miles down the beach and then getting on the highway my gauge would charge itself back up eventually, but by the time i got home, it still had hardly risen above ~13.5 V.
    The next morning i got in my truck to go to school and the gauge was back to where it was supposed to be "~14.1-14.4 V".
    Is this a normal process for optima batteries?
    I am new to the AGM style, when they drain down a little bit, is the recharge process longer?
    Just wondering is this is a problem, or is this something i now have to get used to?
    thanks for your responses!
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    I used these on customers forklifts were I worked. They behave differently than a flooded battery. They take vibrations better but the starting, charging and resting voltage was always different. We since changed back to flooded lead acid and have better results now. We ran computers fans and printers, all drawing juice. The 1 operator said his computer screen was brighter after installing the flooded battery
    2003 Suburban 2500 LT, 6.0l Volant cai. 3.73 gear. Mobil 1 syn oil
    thanks marcus.
    can anyone else with relevant experience chime in on this?
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Last Post: 10-13-2012, 03:50 AM
  2. 04 Silverado Battery question
    By VortecK1ng in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-23-2011, 08:16 PM
  3. Battery Drained. 2000 Silverado
    By Santoy956 in forum GM Electrical Tech
    Last Post: 02-01-2011, 12:16 PM
  4. Question about CV axles on 2000 Silverado NBS
    By lancelincoln in forum GM Powertrain
    Last Post: 03-02-2010, 02:25 AM
  5. 2000 Suburban 2500 Battery Cables
    By silvercat19 in forum General Chevy & GM Tech Questions
    Last Post: 12-10-2009, 07:09 PM
