    Default Need body panels that have power to them at safe levels not to hurt people touching t
    Need body panels that have power to them at safe levels not to hurt people touching them.
    I have seen armor upfitters that will put electrical shock points in door handles so people get shocked but not hurt when trying to break into your car/truck.
    I want to know how hard it would be to actually run power to all the panels in the truck (the skins) that is low voltage to where people would not get shocked by touching the doors or the hood, or the bed, but enough that I could power low voltage stuff right off the panel.
    not sure i understand what your asking. if your asking how to sit something on your hood and power it, cant be done that way. power either dc or ac still requires 2 electrical points. the electric current ran to the panels is actually the result of the human acting as a ground point for an a/c circuit. the a/c circuit is converted from the d/c power supply in the truck. in order to even think of providing enough for the entire truck you will need around 8k amps at atleast 13.1vdc to create 40,000vac. this would also require insulting all of the body panels from the actual 12volt system of the truck. also by doing so the friction from movement for pretty much anything over about 30mph would cause dangerous levels of electro static charge that can cause a discharge high enough to kill a human. cool idea, no real way with todays current tech to truly implement it.
    btw, congratz, this is your 666th post. yayyaayaa you win nothing
    94 sub 6inch lift 34inch bfg mt. massive rework project soon. the audio system hit 150.3db so now its time to rebuild and try for 155db. mudpuppy is also getting a new engine, rebuilt ifs, dual 500amp 15.1vdc alts, 5 5,000amp batts, ant the combined wattage with the new system should be close to 15,000watts. this is going to be a wild ride boy and girls.
    Quote Originally Posted by mudpuppy View Post
    LOL thanks. I don't believe in that stuff....Now it is 667
  1. What to use on black plastic body panels?
    By Pikey in forum Detailing & Truck Care
    Last: 07-27-2013, 04:58 PM
  2. Replies: 0
    Last: 11-11-2012, 08:10 PM
  3. GMT800 Suburban Body Panels 1500 vs 2500
    By rowekmr in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 01-03-2012, 07:26 PM
  4. Replies: 0
    Last: 04-26-2010, 06:40 AM
  5. Direct OEM fit body panels
    By adam4lsu in forum Chevy Truck Accessories
    Last: 03-30-2009, 03:58 PM
