Results 1 to 10 of 11
    May 2012
    Keewatin,minnesota
    Default Intermittent starting problems
    I have a 2001 GMC Sierra 1500 with a 4.8 v8 at ps pb ac 4x4.I have been having starting problems where sometimes I go somewhere then it won't start,turns over fine,gas in tank.I had to tow it home saturday,was going to work on it today.I was sitting in the backyard when I bumped the button on the remote starter fob and I heard my truck start,I have had people say fuel pump,fuel pressure reg.,I'm scared to take it somewhere to plug a code reader in, I can't afford to have another towing charge. Any ideas ?
    How far you away from Iowa??...i have about every scanner you could think of and about every tool/specialty tool you could imagine...if you have any other troubles let me know and i could possibly swing up their IF your not to far away...i wanna say fuel pressure regulator...if i were you and didnt want another tow charge id run uptown and buy the 49.99 scanner at our local auto parts store...
    Line-X'd Bed
    5.3L Flex Fuel
    Factory Black Running Boards
    2" Rough Country Leveling Kit
    EGR In-Channel Vent Visors
    Exterior PLUS Package
    Interior PLUS Package
    K&N Drop-In Air Filter
    Bowtie Mud Flaps
    Cat-Back Dual Exhaust
    Black Bowties
    DeeZee Toolbox(Debadged)
    ProFlaps
    Towing Mirrors
    Next Planned Mods
    Bigger Tires
    Aftermarket Rims
    May 2012
    Keewatin,minnesota
    I'm in northern Minn,but thanks for the offer.
    May 2012
    Keewatin,minnesota
    something different when i unplug and replug the fuel pump relay it will start after the 1st of the day,but you have to do this everytime unless you leave it for 4 or 5 hours
    Oct 2010
    Cobourg, Ontario, Canada
    Quote Originally Posted by ChevyBoy2009 View Post
    what a nice offer ...Brian
    Silverado Crew.....4.8 L
    Quote Originally Posted by bear6232 View Post
    I wonder if it is just a bad relay. Is the relay hot after you run it for awhile?
    May 2012
    Keewatin,minnesota
    going to change relay tommorrow,don't think this is it,it's like it thinks there is fuel pressure to start but there is none because after the initial start up the next try it will start and die
    Have you put a fuel pressure gauge on it? I would see what it does. The pump could be getting warm and not working properly. I doubt that it would take 5 hours for it to cool down though
    May 2012
    Keewatin,minnesota
    tried todrive around the block after int.start could not make it around the block died when got to my back yard let it set 30 min then it started and finished parking it but would not start right away when i talked to one of my mechanic friends he suggested sawing the exhaust pipe off in front of the cat to see if there is an exhaust restriction
    Jr. Engineer Jamm3r's Avatar
    Dec 2012
    Minneapolis area
    Hello from south of the cities, Bear. My stepkids are up in greater metropolitan Hibbing this week.
    You need diagnostics to get to the bottom of this otherwise there's nothing but expense and frustration.
    Measure fuel pressure at the rail and make sure it's in spec and stays there. Borrow a fuel pressure gauge from someone or buy a cheap one from a parts place.
    Failing that pull the codes. You can get OBD-II scanners for $30 these days and if you have a smart phone you can run Torque and use a bluetooth scanner for a few dollars more and get a better and easier to use setup.
    If fuel pressure is good and no codes then you can explore weird unlikely stuff but chances are those two steps will identify something
  1. Intermittent Starting Problems
    By bear6232 in forum General Chevy & GM Tech Questions
    Last Post: 05-16-2012, 11:13 AM
  2. 2003 Tahoe z71 Intermittent Starting Problems
    By John_03z71 in forum General Chevy & GM Tech Questions
    Last Post: 01-21-2011, 05:04 PM
  3. Weird noise starting, intermittent
    Last Post: 11-12-2010, 11:49 PM
  4. starting problems
    By Samuelg35 in forum General Chevy & GM Tech Questions
    Last Post: 01-21-2010, 02:44 AM
  5. Starting problems
    By Soarer in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-08-2009, 08:39 AM
