Results 11 to 16 of 16
    No vehicle has this (at least, not the ones we are talking about). The parking brake is only a parking brake.
    I guess I am not clear about the original post. I did not see a year/make/model.
    Here are pics I took when replacing my rear disc's and there is no question it is a combination Disc/Drum setup. The discs are for regular braking and the drum is for the e-brake.
    http://www.gmtruckclub.com/forum/alb...#axzz2CGKC6I7W
    I believe all GM trucks (at least since the 1999/2000 change over have both let me explain). My 2000 silverado has 4 wheel discs with ABS.
    However the rear axle is a combination Disc/Drum where my powered brakes are discs, but the drum is there for the emergency/manual/parking brake that you press with the parking brake pedal.
    Not sure what model year they changed it on but GM trucks are back to rear drum brakes, they may still use Disc's on some models, but the standard GM truck braking system is Disc front Drum rear again.
    you are very correct on that comment with the power of drum brakes and the use of the emergency brake performance. I would never rely on my rotor park brake shoes to hold my 20 ft boat on the boat ramp. I carry wheel stops just in case they are needed.
    How do Silverados with the Max Towing package with 4 wheel discs do the parking brake thing?
    Yes there are trucks that have it @RayVoy the very late 90's trucks had them because they needed a better parking brake then the discs. I have several diagrams in my manual for 88-98 trucks it applies to 98's with full disc brakes most were 2wd and smaller, but it was eventually put on bigger 1500 trucks. The point is drums are better parking brakes because of their larger surface area.
    No guys, you missed my point. What I was trying to say, was that in today's trucks, there is no such thing as an emergency brake, we have parking brakes (I had hi-lited the section I was referring to)
    By emergency brake, I mean a brake that can slow/stop the vehicle if the main braking system fails. This is why the main braking system has 2 master cylinder pistons and 2 separate pressure circuits.
    The rear rotor has a built in drum (the rotor is called a top hat), there is a shoe inside the drum that is used as a parking brake, check out the link @nakranij posted.
    Your correct, it's mistakenly called an emergency brake but they really cant and shouldnt be used for that purpose, their actually listed as parking brakes in the owners manuals.
  1. Uneven wear on rear drums
    By Caddiac in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 10-12-2011, 07:24 PM
  2. rear disc brakes? 2006 Silverado
    By Scooter in forum Lifted & Offroad Suspension
    Last: 01-15-2011, 07:55 PM
  3. Parking Brake Adjustment? - 2006 1500 w/ rear drums
    By brtt485 in forum Lifted & Offroad Suspension
    Last: 08-02-2010, 01:31 PM
  4. Having trouble bleeding my rear drums???
    By vettetrax in forum Lifted & Offroad Suspension
    Last: 12-14-2009, 01:51 PM
  5. Suggestions on getting rear drums off of 1990 GMC Suburban
    By rfdillon in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 10-27-2007, 08:38 PM
