Results 1 to 9 of 9
Thread: Fuel Pump Live
    Default Fuel Pump Live
    I have a 2001 Tahoe, 5.3Vortec. Has only 35Kmiles (was about 3 years in a Car Sale Lot), and this monthday fuel pump died.
    Is this ussual?
    If not:
    What could yield to such a ridiculous lifetime?
    Best regards
    Oscar
    PS:
    Fuel economy in citi driving of this car?
    First welcome aboard,
    That does sound a little soon even on these pumps. I do believe that if you put a GM replacement pump in they are guarantied for lifetime. Not sure check that out before you get it done, and I do believe the dealer has to do the install, not sure.
    They do have a bad habit of going on us. GM I think didn’t put a good pump in the beginning. Sorry to hear the thing went on you so soon, but are you sure it’s gone and not just a plugged filter?
    Replace the filter anyway because if it sat that long chances are it’s plugged.
    If that doesn’t work then replace the pump.
    And one Big Pain in the Ass When it Doesnt.
    See a Pattern yet?
    Yea, our trucks fuel pumps are very sensitive. If you run them low on fuel too often you will usually need a new pump prematurely. Being as it was on a car lot so long, I'm sure it had many times that it was run (test drives, etc.) that it was run with very little fuel in the tank.
    But like stated above, replace the filter too. Also, there could be trash or something in the tank, or even a bad fuel line as much as that thing sat.
    1999 Sierra ECSB, 5.3L, 3.42 Locking Rear, True Flow Filter, Dynomax Super Turbo, Lund Genesis Tri-Fold, Bully Tailgate Lock
    I agree with the above posts. The pump is liquid cooled so running it really low causes it to over heat/die prematurely in the long run.
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
    Master Mechanic TahoeFever's Avatar
    Sep 2007
    Now IN Auburn AL :)
    Quote Originally Posted by Yukon-tico View Post
    Is this ussual?
    If not:
    Best regards
    Oscar
    PS:
    with only 35k you should and actually supposed to been offered the mgpp , major guard protection plan.
    with that your fuel pump should have been covered since it was on the lot for most of that time.
    Since the warranty expires at 35k ...guess thats a no go ..and no the fuel pump issue is not a common thing to happen usually after 100k + or so ...yah maybe and as for the miles around the city it depends on how you drive the truck..dont gun the sucker at the green light will help big time
    04 Tahoe LT 5.3L stock MSD 8.5mm Wires
    Gigbson Duels Straight Exhaust, Parrot 3100 Bluetooth
    K&N 77 Series CAI, Sirius Radio
    De-badged, Valet Dei remote start
    5000k HID -Higherlevelauto.com
    Federal 100watt air horn
    Oct 2007
    north of Boston
    I get about 13mpg w/ my 01 tahoe 5.3L
    3 yrs on the lot! 3yr old gas isn't so good!
    Does the truck have 135K miles? not hard to change to instrument cluster!
    Default Fuel pump life
    Well, Im pretty good teached by this time. Thakns a lot.
    1. The fuel in my country is one of the worst you can find in America (I bet only Cuba may have something worst)
    2. the car was used several times with quite almost empty tank
    3. I added an Injector cleaner one week before problems came. Same thing happened with my old 2 door Yukon (sold 4 months ago, picture attached) and problem was very similar: one week later fuel pump KAPPUT!
    4. Ive being driving this car with abiut 1/4 tank in sinuous and climbing roads (you can easily find them in Costa Rica), and Im not a slow driver.
    5. Fuel filter was changed a copule days befor pump problem, and I found that filter was partly clouged, and there was low fuel preassure in tank
    6. I changed the pump, US$400!!!
    Best Regards
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    I would check on recalls for your Tahoe. I have a 2001 Suburban 1500 with the 5.3 and there was a recall on the fuel pump that the dealer replaced for free (Even though my Burban was out of warranty). It could be the same with your 2001 tahoe.
    Darcy
    Washington State
    Jan 2008
    Ashland Missouri
    For what its worth i had a GM tech tell me about a year ago when i was changing fuel pumps in my 97 Z-71 that alot of times its the wire connections on top of the pump instead of the pump itself.He showed me on my old pump that one of the connections was loose.I stood and watched as he cut the ends off of the wires and spliced on new ones.Kinda scary but so far no more problems but i still replaced the pump cause it was still under warranty.
    Terry
    2004 Tahoe (wifes)
    2004 Silverado 2500HD Duramax
    1997 Chevy Z-71
    1953 Golden Jubilee
  1. Which fuel pump do I need?
    By Keats in forum Performance & Fuel
    Last Post: 05-12-2010, 12:35 AM
  2. Is it my fuel pump
    By treysanatomy in forum Chevy C/K Truck Forum
    Last Post: 02-06-2010, 03:10 PM
  3. fuel pump
    By chevy58 in forum Performance & Fuel
    Last Post: 07-23-2009, 07:35 PM
    Last Post: 09-26-2008, 05:10 PM
    Last Post: 09-05-2008, 02:55 PM
