    Jr. Apprentice Rugby Wallaby's Avatar
    Sep 2008
    Kingdom of Saudi Arabia
    Default 07 Suburban Sunroof Tracks
    Recommendations re lubrication of sunroof guide tracks - Necessary? What to use?
    thnx
    Dave
    Currently KSA
    Home: Northwest NSW
    Australia
    I've been spraying silicone spray in my wifes HHR sunroof tracks every oil change.
    I use a silicone grease, the spray is good but there's overspray. Also the grease stays put!
    I use white lithium on mine. There was a TSB a few years ago about Cadillac sunroof issues, that TSB called for Rheosil 500F from Tai Lubricants as the preferred grease. From the manufacture website: A lithium soap thickened, medium viscosity silicone grease fortified with PTFE for added lubricity. Ideal for plastic on plastic and plastic on metal applications and control cables.
    So, I guess lithium or silicon will work fine as the recommended product is a combination of both.
  1. 2005 Suburban LT Sunroof problem
    By happy_camper_nj in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-01-2014, 08:26 PM
  2. How not to go over some railroad tracks.
    By nickpatton_189 in forum Lifted & Offroad Suspension
    Last: 05-14-2010, 08:33 PM
  3. 2003 Suburban sunroof problem
    By Jacobd in forum Member Introductions
    Last: 02-16-2009, 05:22 PM
  4. 2003 Suburban sunroof problem
    By Jacobd in forum Chevy SUV & Crossover Tech Forum
    Last: 02-15-2009, 12:38 AM
  5. Q&A: US Snowboarding Champion Louie Vito - First Tracks
    By ChevyFan in forum Chevy Avalanche Forum (Escalade EXT)
    Last: 04-24-2008, 11:30 AM
