    Default Rear wiper arm replacement
    Help!
    I have a '98 Tahoe with a rear wiper on the back window. The wiper won't clear the glass surface, so I bought a new wiper arm.
    Does anyone know how to remove the old arm? Do you have a GM or Haines Tech manual that tells you how?
    Many thanks!
    =Jay
    Quote Originally Posted by Jay57NJ View Post
    Help!
    Many thanks!
    =Jay
    Rear Window Wiper Arm Replacement
    Removal Procedure
    Disconnect the washer hose.
    Lift the wiper arm from the windshield.
    Disengage the retaining latch with a screwdriver.
    Disengage the washer hose and grommet from the liftglass.
    Remove the wiper arm from the wiper motor drive shaft.
    sorry it had pictures when i copied it
    Chevy parts
    OK this the closest I could find after doing a search, On my 2003 Yukon XL where do add washer fluid for my rear wiper? Do I need to pull off my rear hatch panel I just can't find the reservoir
    Master Mechanic TahoeFever's Avatar
    Sep 2007
    Now IN Auburn AL :)
    your rear wiper feeds off of your main reservoir in the engine compartment .. if you are not getting any fluid to the back take a look on the driver side in the engine compartment there is a T joint tube that joins the rear to the front ..sometimes it comes off .
    04 Tahoe LT 5.3L stock MSD 8.5mm Wires
    Gigbson Duels Straight Exhaust, Parrot 3100 Bluetooth
    K&N 77 Series CAI, Sirius Radio
    De-badged, Valet Dei remote start
    5000k HID -Higherlevelauto.com
    Federal 100watt air horn
    Well if thats not the goofist thing ??? if the hose had a leak then my tank would drain, I don't have that issue my front sprayers work fine. OK so where is the pump is it trying to push fluid some 20 plus feet or is it drafting it 20 plus feet?
  1. Rear wiper washer fix.....
    By flamecop in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-13-2010, 06:23 PM
  2. Rear wiper blade replacement on 07+ Trailblazers
    By jeff618 in forum Chevy Trailblazer Forum (GMC Envoy)
    Last: 01-25-2010, 07:17 AM
  3. Anyone have a rear wiper motor go out?
    By silveradojc in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 11-19-2009, 04:53 PM
  4. Replacement wiper arms 2008 Sierra
    By fishcraz in forum General Chevy & GM Tech Questions
    Last: 05-15-2008, 07:53 AM
  5. 03 tahoe rear wiper
    By bigbrett in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 12-17-2007, 04:47 PM
