Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Former Member
    Apr 2012
    Reading, PA
    Quote Originally Posted by sandpiper97 View Post
    I think buying some type of tire chain is a foregone conclusion since Oregon requires at a minimum to carry them even though GM says not to use them. Talk about a Catch 22. Second, traction tires don't appear to be an option in Oregon for vehicles with a GVWR over 10,000 lbs, "You must use chains on any single drive axle vehicle rated over 10,000 pounds GVW." And, "In typical winter conditions, vehicles rated at 10,000 pounds gross vehicle weight (GVW) or less and not towing or being towed are allowed to use traction tires in place of chains." By omitting 10,000 or above, they are saying I need chains. So traction tires don't appear to be an option for me.
    If you read the fine print, I will bet you find that only applies to commercial vehicles...I drove all over Oregon in the winter, and never once was stopped for, let alone asked, if I had tire chains. Besides the portion you quote: "on any single drive axle vehicle" means a 2wd, not a 4wd. I was also all over the Rocky's with nothing more than either a set of Revo II ATs or a set studded Cooper M&S, I never found a single place I wasn't comfortable going.
    OP, I would look at a true set of winter tires, with the severe weather rating symbol (the snowflake and mountain)...if you're out on winter roads, the highway patrol WILL look for that if you are stopped...they asked me about this little symbol, but not about tire chains. The Cooper Discoverer M&S is a true studdable snow tire that works very good (I had a set of these in the 265 flavor)...they can be had in Load Range E. When studded, they are a formidable tire on winter roads. If you are looking for something to run year round, I would take a set of Bridgestone Revo IIs over a set of BFG A/Ts (based on my experience for both).
    Here is a link for the (wrong size) Cooper M&S: http://www.bigotires.com/Tire-Detail...ERER-M&S/13123
  2. #22
    I want to know if there is a link to NC laws on chains, or studded tires. I am told they are illegal, but I am sure in the mountains they can't be illegal. It was explained that we aren't allowed to use them here because they tear the roads up, but we have just enough hills here in central NC that I have been stuck a few times and something for a little extra traction would have been nice.
    They are actually legal and may be used under certain conditions. The law is here: http://www.ncga.state.nc.us/gascript...statute=20-122
  3. #23
    That is awesome, thanks moogvo, I think I am going to order me some. I assume chains won't make any difference in ice? or maybe the would rough up ice to get something over a rubber tire.
  4. #24
    Most people only use chains on the drive wheels for traction. I suppose you could put them on all 4. Have you ever driven a vehicle with chains? If not, there are things that you need to know BEFORE buying ANYTHING...
    First, Once you install chains, your wheel is no longer anywhere NEAR balanced - you cannot drive the vehicle at highway speeds with chains. The max safe speed is about 30mph, so this isn't something you can put on when there is a chill in the air and take off when you see new grass starting to grow.
    Second, Chains do not last long. They will wear out really quickly and will become projectiles if left on too long. Driving over dry pavement kills them fast! Having a chain break will absolutely rip your fenders apart before flying off to destroy someone else's windshield. Bear in mind that YOU are responsible for any damages that are done by your chains. Most insurance companies will NOT cover damages to your vehicle or others by use of chains. Make sure you are covered!
    I lived in the NC mountains for several years. You really don't NEED chains to get around. In some cases, a 4x4 is a must, but most of the time a 2 wheel drive is fine. If the weather is too treacherous for a 2 wheel drive, you might consider staying home! Chains are a pain in the ASS!
    You MIGHT get some benefit by using chains in the ice. Whatever gains you see, it won't be much.
    Just be careful regardless of what you decide to do.
  5. #25
    Well said.
  6. #26
    Sorry, that is not the way the front operates. The diff is an open differential and at no time are the two front axles locked together creating a solid axle. The actuator is on the passenger side of a 4x4 truck and connects the outer half of the passenger side axle to it's inner half. The actuators purpose is to connect the passenger wheel to the front differential. Because the front diff is "open" there is only one front wheel receiving power at any time (the wheel with the least resistance). Without the operation of the axle actuator, the axle shaft on the passenger side would be the one with the least resistance and front power would not be directed to a wheel.
    And, with regard to the chains, I stated, this was only my 2 cents based upon my experience.
    I am going to have to agree with rayvoy on this one.
  7. #27
    Former Member
    Apr 2012
    Reading, PA
    This depends on the chain...a set of "V" groove chains are pretty impressive on ice. I've driven 4wd pickups with "V" type chains out plowing, on solid ice its pretty much normal driving, but they eat up asphalt driveways.
    I rarely see anyone around here with chains, most people have 4wd/AWD vehicles, install snow tires, or both (I'm the latter).
  8. #28
    Just an update on my winter driving issue. I drove over Mount Hood (Highway 26) on Dec. 20th. Hard packed snow for about 20 miles. 4-wheel drive handled it nicely. Signs indicated chains or traction tires were required. I did buy a set of chains just to carry in the toolbox and meet the carry chains requirement by ODOT. Otherwise I understand they can turn you around if you otherwise get stopped for another matter. So will go with this and only use the chains if absolutely necessary. Happy New Year everyone and thanks for all the good replies.
    Bob Dolan
    2012 Chevrolet Silverado 3500, 4X4
    Single Axle, Long Box, Crew Cab
    6.6L Duramax, 6 speed Allison
  9. #29
    I used to live in Oregon, I carried chains and never used them and never had Odot question me even going over Hood to Bend or from LaGrande to Pendleton. My tires had the little mountain symbols on the sides of the tires so that they were Odot approved. They don't have to have studs to be approved. If you get stuck is when you will get in trouble and then it is a hefty fine.
    Ford has a better idea! Drive a GM!
    07 GMC Sierra Classic
    07 Honda Accord EX-L
    68 Camaro (blown)
    2011 Ford F550 V10
    I don't own this truck, I just drive it!
  10. #30
    God help you if you try using a set of cables in place of chains in real ice and snow, over any normal road. Have you never noticed how many cable sets are strewn on the highway after a major snowfall??? they are crap, meant for absolute minimum use.
    GM is protecting themselves from litigation by not recommending chains. Chains will damage any vehicle if they are improperly installed, or if they break (very uncommon). Living 12 years at Lake Tahoe, and driving over the passes every week for the entire time I was there, never once was I required to install chains (operated various 4x4 pickups). However, I was often required to show that I had them. If I had not had them, I would not have been allowed over the pass. Carry the chains, use them if needed, practice installing and removing them several times before first time of potential use. Be sure your rubber snubbers are in good condition, and do not be stupid and use light-duty shock cords, like I see a lot of idiots doing. Good luck. Oh...as for spider spikes...they work well for one season on a light vehicle (3000 pounds), and if going short trips on smooth roads. Don't even think of using them on a heavier vehicle to cross over long passes that may have ruts, potholes, etc.
  1. Greetings from the P.a Mountains!
    By PaPipeliner in forum Member Introductions
    Last Post: 05-19-2012, 08:18 AM
  2. Went up to the mountains today.
    By Jimmeh in forum Photo & Video Gallery
    Last Post: 03-04-2012, 09:44 AM
  3. Winter driving in Utah
    By Coach24 in forum The Coffee Shop ~ Chit Chat
    Last Post: 01-24-2012, 10:08 PM
  4. Newbie from the So Cal mountains!
    By C. Alan in forum Member Introductions
    Last Post: 11-01-2011, 09:34 AM
  5. A few pics of my winter Rig in Alaskas harsh winter
    By lilgoat11 in forum Photo & Video Gallery
    Last Post: 06-06-2011, 10:50 AM
