Thread: 88 s10 questions
11-17-2012, 01:45 AM #1Newbie
- Join Date
- Nov 2012
- Location
- Oregon
- Posts
- 6
88 s10 questions
I just recently bought an 88 s10 long bed, and because I like to know what I am dealing with, I did a google search on the one I have.
My s10 is a regular cab long bed with a 2.8l v6, and a 5 speed manual transmission. According to my search, there was no such thing. Multiple sources said "Only the EL Regular Cab Short Bed 2WD and Extended Cab Short Bed 2WD got a standard five-speed manual transmission with overdrive. The other trims got the four-speed automatic transmission with overdrive. "
Is this right? Was there special orders? Did they just have bad info to go on?
Other than this, it seems like a good truck, a few small repairs. Also one slightly bigger fix. The previous owner tried to adjust the timing, and broke off a piece of a screwdriver in the cylinder while trying to find top dead center.
The piston and valves in it are still good, no damage, and hasn't been started since that happened.
I don't know much about mechanics, but even I know not screw around like he did. (No pun intended)
Other question, How easy are the s10 trucks to work on?
Also, there is only 70,000 original miles, and I paid only $425Last edited by Belairien; 11-17-2012 at 11:43 AM.
11-17-2012, 04:39 AM #2Legend
- Join Date
- Apr 2010
- Location
- Piermont,NY, back in Northern NJ now, But may be in IL soon....
- Posts
- 4,274
My first truck was a 88 S-10 Blazer.. I loved that truck.. I had the 4.3 in it.. As for the 2.8 (which is a good motor) I think I can remember seeing them in the PU's there was also a 2.5 which was called the Iron Duke made by Isuzu A great motor..
08 Z71 Avalanche Mods to date: K&N CAI,Hellwig Swaybars and End Links, Corsa Sport Exhaust, Superchips Programer,IPCW LOF & 3rd brake light and tails, AMI Gas door,Show Hooks and Door locks, Enkei Wheels, with Pirelli tires, StreetScene Bowties, Grant Steering wheel,Muth signal mirrors,SSBC Big Brake kit,Huskyliner Mug gards,Floor mats and Hood shield, McGard Lug nuts and locks,Bedrug, Cervini's Ram Air hood,35watt HID Fog lights, Sylvania bulbs all around ZXE's Highs and Lows, WhiteNight Back up lights,Sirius and HD Radio, SnugTop painted and on, PerryCraft Rack system with Kayak and Bike Holder, Tempress Boat Hatches....
New Bilstein shocks on the way... New Mods coming soon..... X
11-27-2012, 03:19 PM #3
If I recall correctly, the 2.8l with the 5 speed was common for 88's. I had an '87 with the 2.8 and auto, and it was a pretty good truck.
Did you get the screwdriver piece out of the cylinder yet? If you have to remove the head, don't worry about it. It's not too bad a job. In any case, the two most troublesome parts of that engine are intake manifold gaskets (leak coolant into the oil) and the distributor o-ring (leaks oil down the back of the engine), both of which you will replace when you take the head off. I would suggest you find a manual for it, or find someone who knows how to work on it before you start tearing it down.
I'd say for $425, if the body is good, you have done well.
Good Luck and God Bless.Remember that if you're not part of the solution, then you're part of the problem!
11-27-2012, 04:41 PM #4Newbie
- Join Date
- Nov 2012
- Location
- Oregon
- Posts
- 6
Well the engine is toast. body still worth it though.
The guy I got the truck from said he looked in it with a small camera, like what doctors use to look inside you. But even the lowest quality camera with even a little light could have seen that the piston was cracked, and the sides of the cylinder were scored up. there was even a gouge in the head. Only way they could have done that was trying to turn it over with the screwdriver bit still in it.
Even with the damage, the head is still good. Valves are good, and the gouge didn't crack anything, and was in a very thick part of the head.
Body is good, other than some minor interior repairs, and a rear bumper.
At least it was worth the money spent, I just nee to save for an engine now. Won't be too hard with my new job.
11-27-2012, 05:46 PM #5
If the engine only has 70,000, here is a good possibility that engine can be saved.
You'll have to pull it, take it apart (or have a shop do it) and get the damaged cylinder re-sleeved.
While it's apart, have them clean up anything that needs it, put it back together and re-install.
Cheaper than a rebuilt and more reliable than a junker.Ray
11-27-2012, 06:01 PM #6Newbie
- Join Date
- Nov 2012
- Location
- Oregon
- Posts
- 6
That's one of the things I'm looking into. But first I have to save the extra cash. Other than that, a local scrap yard has a running engine with a warranty for 800. I have time to make a well informed choice, since it will be a month or so of work to save up. But I made a commitment when I got the truck to get it running. And I won't give up.
Maybe someday I will even put a 350 in it.
11-27-2012, 06:30 PM #7Similar Threads
New with a few questions
By Jasonch in forum Medium-duty Truck ForumReplies: 2Last Post: 01-14-2012, 11:52 PM -
HID Questions
By 763chev in forum Lighting DiscussionReplies: 2Last Post: 09-22-2010, 07:00 PM -
header questions? and other exhaust intake and tune questions?
By elkosp16 in forum Performance & FuelReplies: 16Last Post: 07-19-2010, 04:56 AM -
First time towing questions.. Tire psi/Air-bag questions
By beforeiforget761 in forum Chevy Silverado Forum (GMC Sierra)Replies: 2Last Post: 05-16-2010, 07:39 PM -
new guy, a few questions
By aisabell in forum Chevy Suburban Forum (GMC Yukon XL)Replies: 6Last Post: 03-22-2009, 06:39 AM
Bookmarks
