Page 5 of 5 FirstFirst ... 345
Results 41 to 48 of 48
  1. #41
    Hmmm, how well do you think it works?
  2. #42
    The commercial made it look like it was magic, IDK. I checked their site, found 2 products, one was a penetrating oil and the other was a corrosion retarder, I suspect the commercial I saw was the penetrating oil.
  3. #43
    Looks sweet. May try that.... Still will get estimates just in case.
    I brought Tahoe to the shop they are going to see what they can do. The head mechanic said he has removed tons of broken plugs, but some time they just don't budge so hes not guaranteeing anything. He also said he has every tool made for the task and tools that kinda just work for it. I told him I don't wanna spend over 300 for this initial try so that's about 3 hours of labor that he will spend trying. He also will replace the other plugs.
  4. #44
    Spent $330 they replaced all the plugs and removed the bad one. All the other plugs came out with out a problem so all it well. She's running smoother, but her bad cat is still hindering her. Did learn I have a coolant leak from the radiator or a hose and its fairly significant, I will have to do a pressure test and inspect it my self. Radiators aren't much any way and in 90's trucks they are easy to remove. I will keep putting coolant in it as it leaks out until I can afford to fix.
  5. #45
    I've heard of this happening on Fords. After reading this I will put PB blaster on any plugs I take out.
  6. #46
    It is more of a ford thing, but it can happen to any car,truck or SUV. There's several lessons here:
    1. Use penetrating oil there is no such thing as to much. (PB Blaster, WD40)
    2. Proper sockets help a lot.
    3. Change your plugs on time or before to prevent problems.
    4. Murphy's Law....
    5. Choose a shop that wants to save you money and keeps you well informed.
  7. #47
    Glad to hear you are back on the road... Enjoy your ride... Next???
  8. #48
    If the leak is from a hose, it needs to be changed; if from a gasket, or from the radiator, there are lots of stop leak produces on the market. Most will stop the leak and the repair will last for a long time (I have even used them in hot water boilers with great success). Bardal has a liquid that's works well, and there is a powered product, I think from Prestone (but not sure) that works well.
    If nothing else, it will get you a few months, or a year, and it is a lot cheaper, not to mention safer, than antifreeze.
  1. oil on spark #7 spark plug
    By kawierider1990 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-30-2012, 05:49 AM
  2. Spark Plug?
    By Chevyman224 in forum Performance & Fuel
    Last: 11-05-2009, 06:15 PM
  3. What spark plug to use?
    By partsman in forum Chevy C/K Truck Forum
    Last: 03-09-2009, 12:58 AM
  4. Spark Plug ??
    By Blakjax98 in forum General Chevy & GM Tech Questions
    Last: 01-04-2009, 10:58 AM
  5. Broken Spark Plug
    By Crawdaddy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-21-2007, 06:12 AM
