Results 11 to 16 of 16
    On the gm tranny pan plug , I found that GM used permenent lock tight on these drain plugs. When I have had to remove these type pans , I heat the plug till it glows red then unscrew it. One time as I was heating up the plug the lock tight exploded out. good thing I had safety goggles on.
    Wow, that explains why I could not get either of them out. It does not seem to make much sense to locktight a drain plug in. That would be like putting red lock tight on your oil drain plug.
    yeah pretty much another dumb idea by gm. I tried heating it too, but I didnt get it to glowing as I am always afraid of messing things up that way.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    using a small propane torch heat until it glows red but not too much, then place the cold tool on the stud/plug this then shrinks the plug as the gradual torque is applied it will release.
    must remove pan first !
    trying to remove this plug vehicle 1 yr old 15,ooomi. I applied so much torque prior to the heat process that , the pan was flexing. that told me permanent lock tight. this then I found on other pans of this vintage.
    because of the linkage exhaust and other components the fluid removal before droping pan sure does make it much less of a mess.
    I know what you are saying there. I was planning on draining it thru the plug. When I could not get it out I started to drop the pan. Only then did I realize that the linkage was in the way. What a mess I made. The next time went smoothly without a drop of fluid on the garage floor.
    Oct 2010
    Cobourg, Ontario, Canada
    I think I will get a plug made in the spring for our crew cab....I would probably change the
    Granny fluid then every year as maintenance....thanks to any or all for this interesting thfead
    Silverado Crew.....4.8 L
  1. What do you think about this idea? good idea or dangerous?
    By tnelson73 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-02-2012, 05:23 PM
  2. Is this a good idea to save gas at the pump? (Increase MPG Idea)
    By ShadowRejects in forum Chevy C/K Truck Forum
    Last Post: 10-22-2011, 01:38 AM
  3. Transmission Cooler? Need to drain out a quart of Transmission Fluid
    By Fitzi722 in forum General Chevy & GM Tech Questions
    Last Post: 06-30-2011, 10:38 PM
  4. 09 silverado exhaust good idea or bad
    By 09silverado in forum Performance & Fuel
    Last Post: 03-18-2009, 11:28 PM
  5. ok so i had a good idea
    By 89suburban350 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-08-2007, 08:04 AM
