    Default 2011" Yukon XL 2500 Rough Idle/Power Issue.
    I have a 2500 xl that idles rough......wants to up shift on hills then lug out . Seems to over rev when coasting downhill. I know it has a clutch to clutch tran and can deal with those pulses... But the power loss seems just not right. Any direction? Dealer tech shows no errors, shows a bull. On the idle ...just deal with it kind of thing. HELP.
    I can't help with your issue but wanted to welcome you to GMTC!
    Welcome to the club, it's good to have you aboard. Good luck figuring out the problem. Sounds like you should find a better dealer maybe.
    I would check the egr valve. It may be clogged or sticking
    Welcome to GMTC, hope somebody can help you with your problem.
    1994 GMC Yukon, 2 door, Victory Red
    Garage Link: http://www.gmtruckclub.com/forum/sho...1994-GMC-Yukon
  1. rough idle 4.3 v-6
    By RATRODKING in forum GM Powertrain
    Last: 05-03-2010, 03:21 AM
  2. Rough Idle, Loss of Power. Had codes checked but now need help on where to go!
    By JEM2121 in forum General Chevy & GM Tech Questions
    Last: 09-11-2009, 12:10 PM
  3. rough idle
    By BigE in forum General Chevy & GM Tech Questions
    Last: 05-11-2009, 01:24 AM
  4. rough idle
    By RLawns in forum General Chevy & GM Tech Questions
    Last: 02-03-2009, 12:11 PM
