    Default location of 4x4 actuator
    folks, I need to know the location of the electronic actuator, and how to service or replace it. I see a lot of mentions here about it, but a search did not turn up answers for me. Thanks for the help.
    Jim
    what actuator are you refering to ? the locking actuator is for the front axle differental gear box. the encoder motor is for the 4wd mounted on the transfercase.
    what are the GM specific drive train failure codes?
    If you are talking about the front axle actuator, it is on the front axle, in the front, closer to the passenger side. It screws into the front diff and has a wire running to it. You just unscrew it and replace it. If you are talking about the encoder motor, it is on the front of the T-case.
  1. Yukon Denali seat recline sensor location and adjustable pedal sensor location??
    By Pikey in forum General Chevy & GM Tech Questions
    Last: 11-08-2012, 02:22 PM
  2. actuator
    By joe_c in forum Chevy Truck Tech Forum
    Last: 11-13-2011, 09:02 AM
  3. 4wd actuator motor
    By atridox in forum GM Powertrain
    Last: 06-26-2011, 02:51 PM
  4. looking for adl actuator
    By justaphase44 in forum GM Electrical Tech
    Last: 05-12-2011, 10:26 PM
  5. 4X4 Actuator Location
    By Mike Hill in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 02-16-2011, 01:07 AM
