    Default 02 sonoma p0300, any suggestions ?
    Hello all,
    I have a 2002 GMC Sonoma that is throwing a p0300 and i have literally done everything that I could think of or that has been recommended by others. Its cylinders 1&4 that are misfiring. I took it to the dealership and they said it needed to be rebuilt because of a low end knock. Well i had it rebuilt and it is still doing the same thing. Any suggestions would be greatly appreciated! here is what i have done so far
    - Spider injector replaced
    - Distributor, cap, button
    - plugs and wires
    -Ignition control Module
    - Ignition Coil
    - Crankshaft postion Sensor
    - Cleaned MAF
    - Upper intake gasket set
    I am so lost and have so much in it now that i can't just quit on it, thanks in advance for any help!! have a blessed day
    Quote Originally Posted by BLOWOUT View Post
    You had the engine torn down and completely rebuilt?????
    A here is what i have done so far
    - plugs and wires
    - Ignition Coil
    - Cleaned MAF
    Is this on top of the rebuild, or is this what has been done? Sorry, your statements are a little contradictory.
    Yes sorry about that all of that on top of a rebuild.
    Wow, ok, that should eliminate a low compression problem.
    I4 engine, or the V6
    Is it possible, the problem has been fixed and not cleared from the PCM.
    A P0300 is a random mis-fire, how do you know it's 1 and 4?
    Its the V-6 , and my friend has an OBD II scanner that displays all your engine data and also has a misfire counter. The SES light flashes when at cruising speeds.
  1. PLEASE HELP !! DTC P0300 02 sonoma 4.3L
    By BLOWOUT in forum GM Powertrain
    Last Post: 10-08-2012, 08:35 PM
  2. Replies: 0
    Last Post: 05-27-2012, 07:40 AM
  3. Chevrolet : S-10 s10 sonoma pro street drag racing s 10 sonoma truck
    Last Post: 08-12-2011, 05:40 AM
  4. Replies: 0
    Last Post: 01-10-2010, 10:20 AM
