Results 1 to 2 of 2
    Default 04 Sierra hard start after fill up only
    Hey Guys,
    I've got an 04 Sierra 4.8L with 270 000km on it. It's got a check engine light on for an evap emissions code. It's had the vent relocation done at least 70 000km ago. Just had a tune up, air filter cleaned (K&N) MAF sensor looks clean. It runs a little rough at 1/4 tank and below, and is hard to start only first start after filling tank. when fueling it takes fuel no problem. After fueling It will turn over and catch immediately then stall (roughly .5 a second of cranking) then if i cycle key off, then back on and wait it takes a few seconds of cranking but will eventually start. Has anyone experienced this? It is only when filled and only recently started doing this. I've seen various posts on check valves and FPR's, I'd hate to change the pump assembly for no reason. Thanks in advance.
    Jr. Engineer
    Aug 2010
    eas' bum fuk, maine
    Probably a leaking evap purge solenoid. If its leaking it will dump fumes into the intake during fill up an cause a hard start. Hooked the one up on my alero backwards and caused the SAME problem u discribed because it wast holding pressure. There pretty cheap too and could be what is causing ur ses light.
  1. 2001 gmc sierra hard start fuel check valve question
    By 01sierraslt in forum Performance & Fuel
    Last: 12-06-2012, 10:16 PM
  2. Long story, Helping Marine in Afghanistan. 97 Sierra 5.7 hard start, rough at ^RPM's
    By stevekarns in forum General Chevy & GM Tech Questions
    Last: 08-22-2012, 02:22 PM
  3. hard start
    By cobrown in forum Chevy Truck Talk & GM News
    Last: 03-01-2012, 06:42 PM
  4. hard start or wont start 305.
    By timhall1787 in forum General Chevy & GM Tech Questions
    Last: 09-29-2011, 09:00 AM
  5. Car was hard to start then didn't start at all
    By bmxr123 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-03-2009, 08:48 AM
