Results 1 to 2 of 2
Thread: HID headlights
    Default HID headlights
    Okay so here's the problem. I just put some Xentec HID fog lights on my truck. I had to rig them in there via apoxing them to the light housing. I put them on connected them to the battery and ballest(I know I can't spell) got going down the road with them and they blew a 15amp fuse so I put a 20 amp fuse in and it blew it right away. Any help on how to fix it?
    02 Silverado 2500hd|496ci bigblock|Botch fuel pump replacement|True dual Magnaflows|UV-10 Jensen head unit|All four speaker Kickers|Kicker tweeters|10in Kicker sub|250watt Kicker Amp|Volant Cold Airintake|PowerAid Throttle Body Spacer|33in Nitto Trail Grapplers|8000k Hid Halo Lights
    Did you add relays? Did you add the optional power harness that runs directly from the battery to the headlights? That makes it so you only use your stock headlight circuit for the "on" signal for the lights, not running all that power thru it.
  1. Swap 2 big headlights /grill for 4 small headlights /grill
    By nutlug in forum General Chevy & GM Tech Questions
    Last Post: 07-04-2012, 01:48 AM
  2. different headlights
    By uk mac in forum Chevy C/K Truck Forum
    Last Post: 01-05-2010, 02:53 PM
  3. Headlights
    By phathoe02 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 09-24-2009, 07:59 AM
  4. Headlights dim sometimes
    By Aiblinger in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 02-13-2009, 08:06 AM
  5. Headlights
    By herritage in forum General Chevy & GM Tech Questions
    Last Post: 12-15-2008, 02:45 AM
