Results 1 to 10 of 11
    Default Leaking Trans Fluid
    Hello folks,I have a 1994 Chevy Z-71 4x4 auto with a 350 throttle body,The truck has 54,000 original miles. recently on a three hour trip it leaked a quart of trans fluid which covered the underside of the truck,it does not leak when sitting only when driving.
    Any ideas? Thanks
    Check the cooler lines running up to the radiator, the overflow vent, then the dipstick, then the gasket around the pan.
    I'd buy some cleaner and hose everything down first to get it as clean as you can, after hosing it down put the rear wheels in the air on jackstands and block the front wheels, then fire it up and put it in gear let is run and see if you can find the leak.
    Thanks for the info tbplus10.Maybe that's all that wrong.
    My first guess would be a leaking cooler line, if it's coming out the dipstick or vent then you've got a heat or pressure problem, could come out the dipstick if the vent is clogged, and the last item would be a bad pan gasket which given the age of the truck (even though it is low miles) wouldnt be out of order. Sitting around and not driving is bad on the seals and gaskets.
    Thanks again for your response,I plan on crawling underneath in the morning and see what I can find. I will update what and if I find the problem.
    Were you towing or hauling a heavy load when it happened? Sometimes these transmissions leak fluid out the breather on the top of the transmission case when towing and the fluid gets hot. Also, how hard were you running the truck? (lots of hard acceleration and such)
    Christopher
    Crawdaddy, was pulling an empty trailer and the cruise control set on 70 mph, no excess acceleration.Thanks for your reply. Gonna try to get my old self underneath in the morning and clean things up and see what I can find.
    I spent most of the day trying to find a leak from the trans. I cleaned off everything underneath and drove around some and crawled back under and could not find any leak.The cooler lines are good,nothing coming from fill tube,couldn't see anything from the vent tube. I am going to a mechanic friend tomorrow to put on a lift and let him look.Maybe he can find the problem.
    Thanks for all the advice.
    Quote Originally Posted by RangerJ View Post
    Maybe from the overflow tube at the top of the tranny. Mine's blowing fluid from the overflow tube which is why I mention it. I've yet to address it because other than being messy it's benign (so far). It started doing this one random day; there was no obvious cause.
    Keep us posted?
    Thanks brother SurrrealOne, I ran my hands all over the top of the trans and transfer case and found no fluid.I am flustered.
    Mechanic checked it for me today and found a slight seeping from the cooler lines and stated the vent tube was wet and that's where the fluid came from,but couldn't tell me why . What causes the pressure to blow the fluid from the vent tube????
    Thanks for all the responses.
  1. 4L60E Rebuild Leaking Fluid in OD
    By BMason in forum GM Powertrain
    Last Post: 06-19-2012, 04:39 PM
  2. fluid leaking but what is it
    By Conlan Rose in forum GM Powertrain
    Last Post: 12-31-2011, 04:39 PM
  3. Power Steering Fluid leaking
    By MauryFrench in forum General Chevy & GM Tech Questions
    Last Post: 09-05-2011, 09:42 PM
  4. brake line leaking fluid
    By JROCK_Z71 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-24-2011, 01:28 PM
  5. Leaking brake fluid onto frame
    By horsch32 in forum Lifted & Offroad Suspension
    Last Post: 07-08-2010, 02:56 PM
