    Default "Clunk" somewhere
    I've got a '96 Z71 pickup that has a somewhat misterious clunk when I let off the throttle and then get back into it. The most noticable time is when going over a large hump such as a bridge or railroad crossing. I let off to slow down and the accelerate off of it. This occurs at low speeds, it's not like I'm hard into the throttle. The clunk sounds mid-to-rear of the truck so I originally thought U joints, but nothing seems to have any play in it as far as the U-joints go. There is a little play on either end of the driveshaft but not in the actual U joint. Should it have a little play? suggestions?... Thanks
    spare tire tight?
    Jay :happy: Waxhaw, N.C.
    70 Chevy C-10 Stepside from 86 lowered 2" front 3" back, 383ci/350hp. elec. seats,functioning cowl, wood bed, hidden hitch, hidden tach, long headers, duel 3" exhaust. perform int., semi-aggressive cam (no specs.)
    69 Chevy C-10 Fleetside 350 ci 3spd. mild cam, 270hp,stock.duel 2.5" exhaust. Lowered 2" made own blocks
    89 Ski Marlin Boat 350 ci:party: pulling machine. 7 skiiers.
    Do you have a slip yoke in the driveshaft? Those can clunk.
    Have you checked shocks, springs, sway bars, etc. as far as suspension goes?
    Yeah, spare tire is tight, but no I haven't investigated into suspension. I will tohugh, thanks
    Sr. Apprentice justcuz's Avatar
    Aug 2007
    Alta Loma, Ca.
    Pack your slip yoke with grease and put some on the splines. What happens is they get dry sometimes and will clunk when the yoke moves in and out. Remember the end of the slip yoke has a little hole in it, so it can get a little dirty and rusty in there. Slip yokes on driveshafts with lube fittings will push grease out this hole. Worked like a champ on my daughters 92 Blazer. I thought her ball joints were bad, or a loose u bolt, or the rear slip yoke bushing might be worn. My transmission guy told me about this one. Saved me some money!
  1. Stock "P" rims safe with "LT" tire pressure?
    By xycarp in forum Wheels & Tires
    Last Post: 05-31-2010, 09:38 AM
  2. '04 Silverado "Clunk"
    By APX in forum GM Powertrain
    Last Post: 10-02-2008, 01:59 AM
    Last Post: 06-21-2008, 12:30 PM
  4. "clunk" somewhere
    By MyGreenZ in forum Chevy C/K Truck Forum
    Last Post: 01-24-2008, 04:08 PM
  5. "Monster Mash" Singer Bobby "Boris" Pickett Dies At 69
    By Cableguy in forum The Coffee Shop ~ Chit Chat
    Last Post: 04-27-2007, 10:47 PM
