    Default Do I need to remove half-shaft to replace upper ball joint?
    So, I've read posts and looked at my haynes manual and none of the instructions mentions removing the half-shaft (front drive shaft) to access the castle nut for the upper ball joint. But once I got out in the snowy driveway, took the wheel off and took a peak, i see no way to get that nut off without removing the half-shaft. Am I right or am I missing a trick for accessing that castle nut without removing the half-shaft?
    One reason that particular nut has a cotter pin on it is because it shouldnt be real tight, (book calls for torqing to a certain amount then backing off a half or quarter turn) normally you can get either a box end or open end wrench on it and turn, yours on the other hand looks like it's probably rusted on and will require an impact gun or something equally creative to get off, which will probably mean removing the halfshaft to get enough clearance.
    yep, that one looks pretty rusty. a box end and a cheater pipe might work if you soak in in some pb blaster for a bit.
    Alex
    Quote Originally Posted by Sierraowner5.3 View Post
    Alex
    Thanks guys...good to know it is theoretically possible, and good to know it shouldn't have been torqued down too hard...I will soak with PB for a few days and see if i can make ti work! I'll post results.
    no problem, good luck!
    Alex
    Jr. Engineer Jamm3r's Avatar
    Dec 2012
    Minneapolis area
    There should be plenty of clearance to get a box-end wrench on it. Cutting torch works too, just put a wet rag over the CV boot to protect it.
    Then it's going to take a pickle fork, 16 pound sledge, and some language to get the ball joint off.
  1. Upper Ball Joint Replacement Help
    By rileyjr16 in forum Maintenance & Upkeep
    Last: 09-13-2012, 06:17 AM
  2. grease upper ball joint on 83 k20
    By meborder in forum Chevy C/K Truck Forum
    Last: 08-04-2012, 07:27 AM
  3. 08 Sivlerado Ball Joint upper control arm?
    By DarkCherry in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-16-2011, 10:02 AM
  4. control arm/ upper ball joint
    By bleebs in forum Lifted & Offroad Suspension
    Last: 05-02-2011, 03:48 PM
  5. Upper Knuckle Ball-Joint Replacement
    By GlitchMobile in forum How-to Guides
    Last: 11-13-2008, 03:32 PM
