    Newbie
    Jul 2012
    Northwest Mississippi
    Default 03 Yukon XL - Power Window Intermittent
    Power window (driver's door) stopped working. Pushing the button caused the lights to dim, so I purchased a new motor from CarQuest. In the midst of replacing the motor, the window worked again. I put Humpty Dumpty back together without replacing the motor (which includes removing the whole regulator system and is a PITA). Naturally the window operation failed again later, but is itermittent, and I can't identify a unique circumstance that isolates the problem. I know it won't fix itself, but I'm at a loss as to what is the problem. Does anyone have any advice on how to diagnose the problem before replacing the motor in hopes that solves the problem? The other three windows work fine from both the drivers' door and the individual door buttons. It seems to be a driver's door issue for the driver door window only.
    Kevin
    First, I would start by making sure that it is not the switch. You can pull the switch off and jump the wires to see if the window operates correctly. If that is not the issue then I would pull the door panel apart and run some jumper wires to the motor, this would verify that the motor is bad. If you run a hot wire to the motor and it does not work then I would think that it would be the motor. If the motor operates properly with a hot wire run to it then you have a wiring issue. You might want to start by checking the ground for the motor. Then proceed to check the rest of the wiring with a ohm meter (power off) looking for an open wire. It could get tricky because if there is a kink or break in the wire that reconnects when you move the wire then it is going to test fine.
    Newbie
    Jul 2012
    Pikey - thanks for the advice. I decided to roll the dice and buy a new motor. Took off the door panel, and this time the motor was unresponsive, so I unplugged the connector to the old motor and plugged it into the new motor and the new motor responded. So I removed the whole regulator system and started to replace the motor. I had seen several utube videos that said be sure not to let the gear in the regulator spin when the motor was removed. I wasn't confident I could do that so I inquired about a new regulator/motor. It was only $40 more than the motor I bought, so I went that route. Installing the new regulator was easy, and the problem is solved. Now I'm going to play with the old regulator assembly and learn about that gear everyone says not to let spin when the motor is removed. Sounds like a similar situation with a gas leaf blower when you remove the housing that holds the rope...I"ve fought many of those battles with the spring that keeps it under tension.
    Last Post: 10-01-2012, 05:20 PM
  2. Power Window Help
    By lumpy66 in forum General Chevy & GM Tech Questions
    Last Post: 02-01-2012, 07:15 AM
  3. Power window issue
    By sstoner911 in forum GM Electrical Tech
    Last Post: 07-02-2011, 07:53 PM
  4. Power window failure.
    By tigersdl65 in forum GM Electrical Tech
    Last Post: 04-27-2011, 11:14 PM
  5. Power window
    By zamjohn in forum Audio, Video & Gadget Tech
    Last Post: 09-06-2009, 10:01 AM
