    Default Stretching when first started?
    I hear other truck do it. Is it that common? Is it fixable?
    It sounds like a belt. I check the belt and it seems tight enough and good, when I first start the truck after sitting for a couple of hours especially in the morning. It only does it for a minute. Just a little annoying. It has done it pretty much the whole time I have owned it.
    Tim Walters (Curky)
    How many miles do you have on the truck? Also usually screeching indicates a worn belt. It may also be a worn pulley. I would remove the belt and spin each pulley to see if they are moving smoothly.
    42,000 miles. The belt is good. i will check the pulley this weekend. It did when I first bought it and it had 30,000 miles
    Oct 2010
    Cobourg, Ontario, Canada
    morning, Curky..we have had cars and vans over the years where a brand new belt would screech and squeal for what seemed months. I used to spray it every week or so with Wd-40. Makes a mess, but it works. Ultimately, we chnaged brands of belts and it went away. One thing is, keep the screeching belt around for a spare .......ya' never know......have a good day Brian
    Silverado Crew.....4.8 L
    Curky, I'm going to add to the growing list supporting a belt change.
    I had the same problem with an '05 Envoy. The belt looked great, but, there was a squeal every morning for a min, or so, a new belt solved the problem.
    Thank you everyone..... Looks like I know what I am doing first. So, suggestions on the belt?
    AC Delco or Goodyear Gator back.
    Jr. Engineer Jamm3r's Avatar
    Dec 2012
    Minneapolis area
    A couple things.
    Belt squeak occurs more at startup than when running mainly because the alternator presents a heavier load to the belt. In cold weather the power steering pump does, too, because the oil is more viscous. So to troubleshoot belt problems you can let the truck sit with the engine stopped and the headlights on for 20 minutes or whatever and then the alternator will kick out some serious amperage when you start the truck, and if you have belt problems they'll show up.
    The tensioner is a regular replacement item and although they are expensive they should be replaced if there is any play in them.
    Finally if the belt is behaving badly check the pulley alignment with a straightedge. I was pulling my hair out trying to get the belt to quit squeaking on a 1997 Intrepid and it turns out the previous owner had JB-welded one of the power steering pump mounting studs and got a big ball of goo on the back of the pump so it didn't seat in the bracket quite straight. I had to replace the pump and pulley and put on a new belt (the old one was more stretched on one side than the other) to get everything to work properly. Never would have found that if I hadn't got out the straightedge and checked the pulley alignment.
    Hopefully any previous owners in your vehicle's life weren't that clueless but loose mounting bolts, bent pulleys or shafts, or worn bearings can cause misalignment too.
    There are some crap belts out there being sold so stick with the name brands, Dayton, Gates, Goodyear, etc.
  1. Started ordering
    By heavy chevy in forum Performance & Fuel
    Last: 05-27-2011, 09:14 PM
  2. Getting started on my mods,
    By 1bdtrk in forum Lifted & Offroad Suspension
    Last: 01-17-2011, 08:56 AM
  3. Just started here.
    By tomrez in forum Member Introductions
    Last: 08-11-2010, 11:38 PM
  4. Just getting started here !
    By redonblack89 in forum Member Introductions
    Last: 03-31-2010, 10:50 PM
  5. Started de-badging...
    By bigburb in forum Chevy Truck Accessories
    Last: 01-08-2010, 10:31 AM
