Results 1 to 10 of 14
    Default Tire size fitment question
    hi i have a 2003 lifted chevy truck with a 6 in superlift and 3 in body lift, i need new tires and was wondering if a 37 14.50 would fit under it without rubbing. i have 35 12.50's on it now my wheels are 10 in wide. need some advice.
    thanks
    Welcome!
    I'd expect you'd have to trim. However, that's just a suspicion, as I've not dealt with tires that large, before. By the way, I seriously hope you're changing your gear ratios as you're moving up (so that your truck maintains some low-end grunt instead of becoming a dog) and that this is on a 2500 HD or better and not a 10-bolt 1500! (I'd be worried about the rear diff on a 1500 and also concerned about snapped axles on a 1500...)
    Welcome to the G M T C !
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
    Welcome to the club, it's good to have you aboard.............
    to the GMTC
    Jr. Mechanic BillM's Avatar
    Fair Oaks, CA
    I can't answer that, but welcome to the club.
    Bill M. Blown 2003 Tahoe Z71
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Thread title changed to relate to topic and moved to this section.
    TIRES:
    BFG All Terrain KO 315/70/17
    The truck is a 1500 with stock gears and axles, there's 186k on the truck now and hasn't had any problems as far as axles go, thanks for the help
    Jr. Apprentice weswins's Avatar
    Aug 2010
    Edmonton, AB Canada
    Hey, I work at a truck accessory shop and can tell you without a shadow of a doubt that those tires WILL RUB.
    This being said, they will rub on the rear of the splash guards on the front wheel wells and a small amount on the front bumper. If you do not trim these parts, your tires will quickly take care of that for you the first time you head offroad.
    As far as axles, drive it nicely, dont try burnouts on dry pavement and dont expect much longevity on hardware if you wheel it offroad.
    After all that, do it and enjoy it, there isnt much harm you can do in upsizing tires after 35's, the stress is already there.
    Full throttle is never enough!
    1994 Silverado Z71 1500 (everything but leather)
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    With stock gears (I'm assuming 3:73s?), your truck is pretty sluggish with those 35s already. As @SurrealOne mentions, a changing of the gears should be something you are considering as well if you are moving up another 2" or so in diameter.
    There is also a rule of thumb regarding tire width as it relates to rim width. I can't remember exactly what it is (someone will probably respond with the info if you need it) but I think if the tire is 4 1/2" wider than the rim, that may be too much and you'll have to change rims as well.
  1. Wheel/Tire Fitment + TPMS question
    By Harrison in forum Wheels & Tires
    Last: 05-15-2011, 06:40 PM
  2. tire/wheel size fitment
    By monkio in forum Wheels & Tires
    Last: 03-29-2011, 11:20 PM
  3. HMMWV tire fitment question
    By troyb in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-18-2010, 10:50 AM
  4. Speedo issue and tire fitment question on '91 Chevy
    By CHoffman in forum Chevy C/K Truck Forum
    Last: 05-17-2009, 12:30 AM
  5. Tire Size question
    By WFD205 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 04-17-2008, 08:35 PM
