Results 11 to 14 of 14
    Quote Originally Posted by mfleetwood View Post
    There is also a rule of thumb regarding tire width as it relates to rim width. I can't remember exactly what it is (someone will probably respond with the info if you need it) but I think if the tire is 4 1/2" wider than the rim, that may be too much and you'll have to change rims as well.
    The best rule of thumb is to check with the manufacturer as to the maximum size tire for which a wheel is designed ... and stay within that spec.
    Quote Originally Posted by lifted03z71 View Post
    The truck is a 1500 with stock gears and axles, there's 186k on the truck now and hasn't had any problems as far as axles go, thanks for the help
    You haven't stressed it, yet. If you move to shorter gears to restore lost torque and add even more stress with 37's (heavier than your 35's) and then go wheel it in mud pits or the like because you have the 37's to do it ... the axle and diff will be at risk, as what's in a 1500 is lighter duty than what's in 2500's. That's all I was trying to warn you about. If you just want a pavement monster you should have no problems...
    If I upgraded to a 37 12.50 would the tires still rub? I trimmed the front bumper on the bottom so that it would eliminate any rubbing on the bumpe
    It's tough to say. Even though your width would remain the same as what you currently have, you'd be increasing the diameter by 2 more inches, which could have interesting effects when you've got the wheel turned all the way in one direction, when your shocks are compressed, and most probably when both occur at the same time.
    You should probably take some measurements with your truck in each of those conditions and see if you have 2 more inches of clearance. It won't be a perfect answer but it'll give you a pretty good idea of whether or not you've got more trimming to do if you upsize by another 2 inches in diameter.
    With tires the size you are looking into it isn't the back I would be the most concerned with. It's the front! The front IFS suspension is at the upper range of being capable with 35's. 37's to me is asking for trouble. Why? The added weight of the tire which adds additional stress to what concider a "weak" suspension. If you plan to wheel this at all you will be replacing parts real quick.
  1. Wheel/Tire Fitment + TPMS question
    By Harrison in forum Wheels & Tires
    Last: 05-15-2011, 06:40 PM
  2. tire/wheel size fitment
    By monkio in forum Wheels & Tires
    Last: 03-29-2011, 11:20 PM
  3. HMMWV tire fitment question
    By troyb in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-18-2010, 10:50 AM
  4. Speedo issue and tire fitment question on '91 Chevy
    By CHoffman in forum Chevy C/K Truck Forum
    Last: 05-17-2009, 12:30 AM
  5. Tire Size question
    By WFD205 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 04-17-2008, 08:35 PM
