Results 1 to 10 of 11
    Default Truck will not start ~ 1997 GMC with 5.7
    I have a 97 GMC 4x2 with a 5.7, it cranks over and at times it seems like it is going to start but wont. When I let off the key it bumps several times, also while trying to start it it will backfire sometimes. I have replaced the crank sensor, coil and had the icm tested several times and it is good. Any help would be greatly appreciated. Thanks.
    Is fuel getting to the motor? If fuel is, is it at the right pressure? Many things can cause the truck not to start, especially a truck like your which as so many sensors that need to communicate to allow it to start.
    When did this start happening? Was is random or did you replace something and it started acting weird.
    I once brought my truck to a shop after having trouble with a repair, during my work I unplugged the crank shaft sensor, when the shop had finished their work they couldn't get my truck to start and were so confused. They forgot to plug the crank sensor back in... That how easily a starting issue can be caused.
    It started a couple weeks ago out of the blue. If the truck sat a couple days it was hard to start. Fuel is getting to engine but I dont have a gauge. Tried starting fluid with no results, just keeps turning over.
    Do you have spark to all the cylinders?
    Didn't check all cylinders but had spark at two of them, will check rest today. Changed cap, rotor , wires and plugs about a year ago with aftermarket parts.
    There may lay the problem, GM trucks really are built to use AC Delco plugs and usually don't like other plugs. The same goes for wires. Caps and rotors can be after market, but only some brands make ones that are high enough quality.
    Heres a simple list of how plugs should be bought.
    Delco: GM vehicles
    Campian: Dodge
    Motorcraft: Ford
    Bosch: Imports
    OK. Will try changing them out, hopefully a cheap fix.....Thanks. Will post later any results or if I pulled out what hair I have left
  1. 1997 G3500 6.5 wont start.
    By okysmokey911 in forum GM Diesel & DuraMax
    Last Post: 07-12-2012, 09:58 PM
  2. 1997 Suburban won't start
    By rtoney in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-07-2012, 04:50 PM
  3. 1997 z-71 with 6.5 wont start
    By five.fold in forum GM Diesel & DuraMax
    Last Post: 08-25-2011, 08:10 PM
  4. 1997 K1500 No Start
    By ncof300d in forum General Chevy & GM Tech Questions
    Last Post: 01-11-2011, 01:37 PM
  5. 1997 Burb... Dies.. then won't start for 20 minutes
    By ChaosEnvy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-16-2008, 08:04 PM
