Results 1 to 10 of 16
    Default P0449 Ok what part do I need?
    Ok was at the dealer today Got some pics and part numbers to fix this I hope and I can use my Factory Remote start.
    But which one do I need? One part is $26.00 # 25932571 the other I can get for $68.00 # 20995472 this seems to be the part everyone is replacing.
ID:	47146Click image for larger version.
    The scan says Evap Emission Ctrl Sys Vent Valve Solenoid Circ Error...
    Part number 2571 is actually something you can fix yourself, I removed mine this summer as I also had the p0449 code on my 05 silverado. The lid off the top of it comes off, and there is a sponge inside there. Mine was clogged up with dust and dirt, so I removed the sponge and rinsed it thoroughly and blew the canister out with compressed air and the light went out and stayed out, that was 10,000 miles ago.
    As far as the other part number, is that for #8 the unit and hoses all in one? I have never messed with that so I don't know, good luck with your truck!
    http://s1191.photobucket.com/albums/z477/noell1947/pbr%20time/
    2004 Chevy Colorado 2wd/4l60e/3.5 Inline 5
    6-PIAA 520 series yellow ion spot lights 85 watts each
    PIAA quattro fog lights w/extreme white/yellow ion bulbs
    Anzo projector headlights/LED turn signals
    LED underbodys 7-color/LED interior lighting
    JET stage 2 performance chip/Magnaflow exhaust S/S
    Recon Big Rig Lights/LED tail lights/3rd brake light
    Putco LED bed lights/BEDRUG
    Goodmark 2" rise Cowl hood/K&N fipk intake
    98-04' Blazer overhead console & floor console
    40/60/40 seat modified to 40/console/40
    33" Cooper Discovery A/T
    16" Pro Comp extreme alloy wheels
    The little filter up by the filler neck I too took apart and cleaned but it did nothing. I also took the hose off of the part by the extra tire and blew through it and nothing..So next is the other part...
    I replaced part #10 & #11 in your pictures. The replacement is fairly easy if that is what is wrong. I think I paid about $70 for the kit. No problems since.
    Ext Cab 4wd LT
    Check out my garage
    http://www.NStarWindow.com
    could be #10 or #3. they both look like vent valves, depends on the sytle you have. i have seen water get in these and corrode and split the case as well. typically the "control circuit" code is an electrical concern that "cleaning" will not fix. pretty much it means the circuit is not complete.
    some codes depending on the vehicle will set when the vent valve sticks (mechanically and not electrically) typical codes are "large leak" and/or a code that says its venting when it shouldnt be (forget what that code said).
    Part #10 is the $65.00 part and the one most have been replacing. 3# is also a part that the service guy said they replace alot too it's about $28.00 He stocks both.. I think I will get part #10 this week and replace it Sat...
    you could just climb under there and and see what one you have. plus if given the vin number, the parts guy should be able to tell you exactly what one you need. if you indeed have #10 you will also need a small piece of heater hose (1/2" diameter???) and a couple hose clamps because you will have to cut one hose off i believe some however came with that hose and you just replace it.
    I do have both in my truck I am told. He does give all the parts needed for the price so that is good...
ID:	47318Click image for larger version.
ID:	47319Click image for larger version.
ID:	47320Click image for larger version.
ID:	47318I took these pics 2 weeks ago..
    I just reviewed the email I got from the dealership. The parts #3 and #10 look like what I replaced on mine. Let me know if you got the parts let me know when you want to install them.
    2009 GMC Sierra 5.3L running on E85
    Black and chrome
    Volant CAI
    Borla dual exhaust
    Chrome Billet grill
    Tonneau cover
    4300k High/Low Beam HIDs
    Westin Ultimate Bull Bar with PIAA 540s
    Blacked-out tail and third brake light
    part #3 and part #10 are both vent valves and your truck only has one. by the looks of it you have #10 because otherwise it looks like it would attach directly to your charcole canister and only have one line coming off of it. your pic looks like it has two. thats what it looks like to me anyways.
  1. P0449 cel
    By Als09Sierra in forum General Chevy & GM Tech Questions
    Last Post: 09-16-2012, 01:19 PM
  2. Another Code! P0449
    By harristw in forum GM Powertrain
    Last Post: 08-19-2011, 08:48 AM
  3. P0449
    By fleet20 in forum General Chevy & GM Tech Questions
    Last Post: 01-16-2010, 10:03 AM
  4. any help? p0449, p0455
    By Nicholas23 in forum Performance & Fuel
    Last Post: 06-03-2009, 03:23 PM
